Why AIH Delete
Old Apr 3, 2013 | 11:41 AM
  #46
BWST's Avatar
BWST
Got Data?
I would like to get that AIH relay out of there, to reduce clutter and make it easier to spot leaks in the valley. Looks like the resistor mod is needed to avoid codes? Sounds like Shake-N-Bake did not have luck with that.
Snowseeker, you said you pulled everything out and have not noticed codes? Maybe just soft codes are set then. That'll just be annoying on AE then.
Old Apr 3, 2013 | 11:52 AM
  #47
jeffreyt's Avatar
jeffreyt
It does set soft codes, no CEL. Again, that's if the relay itself is removed.
Old Apr 3, 2013 | 12:07 PM
  #48
honeydew's Avatar
honeydew
I get no codes, even soft ones, with the dfuser harness which is just a prebuilt resistor wire. I've got AE now unlike when I originally posted in this thread.
Old Apr 3, 2013 | 01:18 PM
  #49
mtdigger's Avatar
mtdigger
Easily 25 HP and 40 lb. ft. of torque. j/k studawg......thanks for the laugh
Old Apr 3, 2013 | 03:34 PM
  #50
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
To clarify: you get a soft code if you simply remove the AIH and the wiring running FROM the relay. If you pull the relay, you should get a CEL light constantly, just like when you delete the EBPV pedestal and valve.
Old Apr 3, 2013 | 04:11 PM
  #51
Snowseeker's Avatar
Snowseeker
I pulled everything BUT left the relay in and hooked up to the truck side of the wiring. That may be the reason (I like to think so) that I don't get any codes. I removed the heater, its ground wire, and its power wire to the relay.
Latest engine pic I have, see relay still there but no wiring to heater.
Old Apr 3, 2013 | 06:55 PM
  #52
dn29626's Avatar
dn29626
Good thread.
Old Apr 4, 2013 | 09:13 PM
  #53
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
This thread motivated me to get rid of the soft code my computer has had for the last year. I know you guys are picture junkies, so here they are:
First get a pack of these resistors. They are half watt, so the heat dissipation ability is not too high. Good for this circuit, though. I put two together, but You COULD go with just one of them. Two together gives me 1 watt and half the ohms, so I'm down to 235 Ohms/1 watt.
Then, solder two of them to a couple pieces of three inch long 16-18 gauge wire. You could use 14 gauge as well.
A shot of the parts needed to complete the AIH delete mod.
Then get a heat gun and apply the heat shrink. Crimp the connectors on the end.
The finished jumper containing the "computer fooling" resistors.
And the installed jumper on the truck.
Started my truck, pulled the P0541 code and reset it. Then started it again and the code did not come back. All is now good with my truck. No more soft codes left from the mods I have done!
Old Apr 5, 2013 | 12:48 AM
  #54
BigAlsPSD's Avatar
BigAlsPSD
Mike, how come you didn't go ahead and attach another parallel set in series to get back to 470 Ohms?
Old Apr 5, 2013 | 01:40 AM
  #55
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Well Al, I got to wanting to experiment a little.
I decided to try this after seeing some much older posts where others had put two in parallel and had it work. I have seen where others put two pair of resistors in series, but that makes it more complicated for most folks. They also made much longer wires that were grounded in other places far away from the relay, and I thought I would try to simplify it a bit. I have always wondered where that 470 ohm number came from...and now I know it is not as important as the ability to dissipate the heat IF the computer sends voltage to the heater it now thinks is still there. It worked...no more code. Now, if the computer sends voltage across that line for some reason, the resistors are right there in the open. If they burn up, they can't do much damage in the spot I have them.
Old Apr 5, 2013 | 01:47 AM
  #56
BigAlsPSD's Avatar
BigAlsPSD
Complicated? I guess...it's all relative. You could have shortened up the leads then attached another pair and probably been overall shorter, but it will likely work, as it has for many others. You are right it's to dissipate the heat and create enough load. 470 Ohm is the pretty standard load to be sensed so I'm sure that's where it comes from.
I'm sure you'll be fine, I was just curious. Good clean install too!
Old Apr 6, 2013 | 02:18 PM
  #57
Wildfire532FB's Avatar
Wildfire532FB
Does a soft code show up when smogging?
Old Apr 6, 2013 | 06:23 PM
  #58
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Yes. They will show up on a smog check.
Old Apr 6, 2013 | 09:02 PM
  #59
Wildfire532FB
Still no codes?
Old Apr 7, 2013 | 01:28 AM
  #60
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
LOL. Still no codes. It works great for tricking the computer.
The true test of the mod is if I ever go up north and the computer tries to activate the heater. Then we will see if the resistors hold up to the current/voltage running on that wire. If they cannot dissipate the heat, they will burn up and I'll have to go with higher wattage resistors. Where I live in Texas, that will never happen. So....
Alex332
Jan 28, 2012 10:39 PM
A/Ox4
Jul 13, 2011 12:09 PM
audimaster
19
Apr 7, 2008 06:32 PM
JROSCO6
Aug 9, 2006 10:45 PM
dakota joe
Apr 15, 2006 04:42 PM
