Why AIH Delete
Old Oct 20, 2011 | 07:35 PM
AllaboutMPG's Avatar
AllaboutMPG
Why AIH Delete
What is the purpose of the AIH Delete. I did a search and found it mentioned a bunch but not a reason. Is it part of another mod or just getting rid of an unnecessary item?
I'm getting ready to order my AE program and Fuel Rail crossover from RiffRaff but figure I'll go ahead and get the plug with Boost sensor outlet since Clay's shipping me stuff anyway.
Thanks, Paul
Old Oct 20, 2011 | 07:37 PM
timmyboy76's Avatar
timmyboy76
i would say, it opens up the airflow inside the spider assy, also, it gives you a "spare" relay, for if/when your GPR takes a dump.
Old Oct 20, 2011 | 07:40 PM
AllaboutMPG
Is the heater not needed?
Old Oct 20, 2011 | 07:44 PM
timmyboy76's Avatar
timmyboy76
if a manual truck, then trans temp i wouldnt have.
If your not towing much, and you got a auto, then i 'd say, trans temp as well. I would keep the EGT only because, if your even stock running, i've hit 1200+ before on mine, and mines stock. Boost, not having it, will add to your mpg... Maybe boost gauge too, a simple water with soap bottle can detect a boost leak, also, it can probably be visual too.
Old Oct 20, 2011 | 07:50 PM
AllaboutMPG
Thanks Timmyboy. As you can see I had a posting glich and you were so fast you answered before I could fix it. I do have an auto tranny, 285000 miles. Was wondering if I needed that one for keeping an eye on the old girl.
Old Oct 20, 2011 | 08:17 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
The purpose of this product is to remove the restrictive Air Intake Heater from the intake air flow. Removing the AIH coil will not affect cold start up in any conditions. The PCM only commands the AIH to activate to reduce white smoke during extended long idle periods at low ambient temperatures. Specific conditions must be present before the heater is activated per Ford:
  • Ambient temperature must be below 32°F
  • Engine oil temperature (EOT) must be below 131°F
  • Vehicle power must remain between 11.5 and 15.0 volts
  • Parking brake must be applied
  • The transmission must be in Park or Neutral
  • Glow plugs must be off
Old Oct 20, 2011 | 08:27 PM
AllaboutMPG
That's as good an explanation as I could hope for. Unnecessary equipment.
Thanks
Old Oct 20, 2011 | 08:57 PM
hotroddsl's Avatar
hotroddsl
It's one of those 1% components! Only 1% of them will ever be used! But we all get to enjoy the 30% restriction in airflow they ^so generously provide! We should all feel privileged to be graced by their presence!
Jim & fat smart Alec Monty
Old Oct 20, 2011 | 09:03 PM
timmyboy76's Avatar
timmyboy76
WHOOOAA
Back the truck up..first off, OP, where you located?
Old Oct 21, 2011 | 01:54 AM
twags6's Avatar
twags6
Its just one of those fancy emissions things. Makes the truck not smoke when its sitting there in the cold at idle, and like Clay's post shows, its rarely used. IIRC, you should put a resistor in its place though. I wanna say one of the tests you run with AE looks for that and if its not installed, the test won't run.
EDIT: Found it! https://www.ford-trucks.com/forums/1...eting-aih.html It might affect running a buzz test or CCT
Old Oct 21, 2011 | 08:37 AM
Riffraff Diesel
PREMIUM SPONSOR
Only if you remove the relay will it give you an issue with threat test, not with just removing the plug.
Old Oct 21, 2011 | 09:47 AM
bama29fan's Avatar
bama29fan
Im sure Jody could program that out of it in his tunning? maybe have that as an option on his tunes....like a high idle option. IDK...maybe it would have to be done at a live tune session?
Old Oct 21, 2011 | 10:03 AM
hotroddsl's Avatar
hotroddsl
It's easy to turn on or off a function in tuning a PCM! But the PCM still knows that function exists and activly looks for it across the buss, if it is not there the PCM will throw a code, that is a pretty deeply embedded algorithm, I'm not sure if the ford PCM allows for that rewright of code at the at the tuning level used in our programming? That's a interesting question that could lead to a lot of other really cool functions being added or subtracted fror the PCM!
Jim & fat Monty
Old Oct 21, 2011 | 12:12 PM
microdevil45's Avatar
microdevil45
Sorry to jump in but my question is what all would you need to get rid of to completely delete the AIH?
Old Oct 21, 2011 | 01:13 PM
honeydew's Avatar
honeydew
I used this plug:
Riffraff Diesel: RDP AIH Tapped Fitting
and the dfuser code eliminator at the bottom of this page:
DFUSER Diesel Performance Products Exhaust High Performance Part Diesel Intake Diesel Power Chips
eliminator install instructions:
http://www.dfuser.com/Install%20Guid...2004-12-27.pdf
