egt, boost, trans temp guages
Old Mar 27, 2006 | 10:16 AM
dakota joe's Avatar
dakota joe
What is everyone's option on what order to put the gauges in a three gauge pillar configuration?
Old Mar 27, 2006 | 12:12 PM
ryaneverk2's Avatar
ryaneverk2
You're talking about an A-pillar mount? You should probably put the one that changes quickest or varies the most in the mount that's closest to your eye (upper spot). Put either the EGT or boost gauge in that spot, the leftover one of those two in the middle, and the tranny temp one on the bottom.
Old Mar 27, 2006 | 07:42 PM
Ford Truck Racer's Avatar
Ford Truck Racer
I put boost on top because it ain't important to watch, You can control it by your egt's. I put the pyro on the bottom but I think it wouldn't be bad in the center either since you have to look down a little to see.
Old Mar 27, 2006 | 07:49 PM
CAT_man_963's Avatar
CAT_man_963
I have my boost at the top, pyro in the middle, and trans temp at the bottom. The middle one was the easiest one for me to see - so that's why I put the Pyrometer there.
Old Mar 27, 2006 | 08:14 PM
maevans's Avatar
maevans
I have my Quad A pillar pod set up like this - EGT on top, then boost, then trans, and then water. I put the EGT on top because that's the one i watch the most.
Old Mar 27, 2006 | 08:56 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
unlike everyone else, i have to be difficult
http://img.photobucket.com/albums/v3...t/DSCF2821.jpg
Old Mar 27, 2006 | 10:12 PM
jtharvey's Avatar
jtharvey
I've got a quad mount, from top to bottom: Fuel Pressure, Pyro, Boost, Trans. However, I need to switch the boost and pyro. Although the pyro is closer to me, the boost is easier to read since you're eyes don't have to change their focus point as far. They need to be switched because the pyro is the important one. Then, they'd be placed like stroking has his. Trans temp should stay on the bottom, as it can be partially blocked by the pod above. Pictures in my gallery if you want a peek.
Old Mar 27, 2006 | 10:48 PM
foodog2's Avatar
foodog2
Well since mine is a under dash mount my input doesn't really count, but I put the EGT first, Boost second and trans last.
Old Apr 15, 2006 | 04:42 PM
adam hafer's Avatar
adam hafer
Get a 3 gauge top dash mount. I had a a piller mount but after seeing a dash mount I swaped over to it. Like it much better, puts all the gauges right in front of you, and it doesn't get in your way. But anyway with that I put my 6 Gun on the left, pyro in the middle and boost on the end.
waystro
Apr 1, 2013 08:55 AM
tjustice
Jul 23, 2012 08:42 PM
jmunkie13
32
Aug 22, 2007 07:50 AM
imlowr2
30
Jan 28, 2007 07:47 PM
repou
15
Oct 14, 2006 07:15 PM
