Cab Removal
Old Oct 20, 2011 | 06:16 AM
Super Mech's Avatar
Super Mech
Cab Removal
So i own my own repair shop and have worked on countless vehicles of all types. Some jobs big and some jobs small. I've been working on cars my whole life and owned my shop for 12 years. I would like to remove the cab from my 90 F250 5.8 4x4 to finish rust proofing the chassis and to replace the crossmember at the back of the cab. I've already did the back half (removed bed,rust proofed both chassis and bed, added steel diamond plate floor to bed, changed spring shackles and shock brackets, new rear gas tank and fuel pump, rustproof brake lines and painted chassis. But the more I look at this cab removal project the more I get scared. Is it worse than it looks? What has to be removed besides the obvious? I'm scared.
Old Oct 20, 2011 | 07:41 AM
Diesel_Brad's Avatar
Diesel_Brad
If you are looking to remove the cab and nose as an assembly, that would be the easiest. especially if you have a lift.
4 cab mount bolts
2 rad support bolts
Fan and shroud(rad hoses)
All electric plugs going between the body and chassis
shifter linkage & clutch linkage
e-brake cable
throttle linkage
steering linkage
the just pick the cab up a little and look for anything that may still be attached
Old Oct 20, 2011 | 03:41 PM
preppypyro's Avatar
preppypyro
A cab removal is really very easy. I found the hardest part was the rusty bolts, which wasnt that hard at all.
Along with Brads list, do not forget your speedo cable!
Old Oct 20, 2011 | 04:21 PM
Super Mech's Avatar
Super Mech
Do I have to remove the a/c condensor? (a/c works great) I know compressor lines will have to come off.
Old Oct 20, 2011 | 04:25 PM
preppypyro's Avatar
preppypyro
When I did mine, I just undid the a/c lines and let the lines hang.
dayhofffarms98
Jun 14, 2011 08:37 PM
mkaj7475
Jul 23, 2010 10:08 AM
jimlj
Sep 23, 2008 01:20 AM
Roger T. Pipe
Sep 9, 2008 08:02 AM
88fordf150Dave
Oct 8, 2006 11:32 AM
