Maximum Boost?
Old Oct 19, 2011 | 07:12 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
Maximum Boost?
I just ordered the Edge Evolution Juice with Attitude. I need to know if anyone has a recommendation for the maximum boost on a stock motor? I want to program this new tuner to stay at least 15% away from the dangerous range but I don't know what that would be.
My motor is completely stock, has a 3.5" downpipe, and a straight through 5" from d/p to exit.
Old Oct 19, 2011 | 07:34 PM
69cj's Avatar
69cj
Stock engine 28psi max. Edge juice is known to be a torqueshift killer. Wouldn't use it if I were you.
Old Oct 19, 2011 | 07:45 PM
2006powerstroke90's Avatar
2006powerstroke90
I have the Edge Evolution...Not with attitude or anything, the tranny loves it.
I can adjust all my shift point and shift RPMS. not a problem yet.
Old Oct 20, 2011 | 09:07 AM
bodabdan's Avatar
bodabdan
Veteran: Navy
Thanks for the input. I don't mind using the Edge because I have the standard transmission. I put about 5 tranny's in my 97 so I figured it was time for a stick shift with this truck.
Everything negative that I have seen on the Edge tuners always seems to deal with automatic transmissions or using the tuner at the higher output settings. I don't intend to do either so I think I'll be OK.
Old Oct 20, 2011 | 09:25 AM
davidkstyler's Avatar
davidkstyler
If you look in the Tech Folder...
https://www.ford-trucks.com/forums/9...-pressure.html
Old Oct 20, 2011 | 01:12 PM
egregg57's Avatar
egregg57
Edge Insight with Attitude is a torqueshift killer? Please explain! I currently have this in my truck!
Eric
egregg57
Oct 21, 2011 02:47 PM
FroggF350
Dec 21, 2009 01:34 PM
Presa C
Mar 23, 2009 12:39 AM
Kiddy
Jan 20, 2007 09:45 AM
