Wind thru a pipe sound
You running a/m intake? Whats weird is, prior to the first turbo blowing up, i had the W.W. in, never made the sound, and i ran the FIPK/6637, BUT cant confirm if the foil delete was after the tubo popping, and i gutted it, since everything was removed..."-banghead
I guess until i get around to it, i'll just keep sounding like the CORONA commercial.
you'll be shocked how much it cuts back the high pitch noise, just having the tube wrapped! But the factory wrap is the best for noise reduction
Jim & fat Monty
Jim & fat Monty
Thanks Jim. When rolling up the street, hitting that rpm range, it was more/less this,
, then this..
...whatta letdown, but, got a new/rebuilt in the truck, also new/rebuilt in the garage...
FOUND IT......i think.WIth tranny taking a dump (so i thought), and diff seeing better days, i opted to replace the rearend with a used. Not knowing the 04 axle i scored on, had a different yoke, plus, the damn lug bolts are a fine thread..(99-03 have course), i needed my truck, more than ever. So, i FOUND a 00 axle, with the correct yoke. With tranny on jack, and old axle out, i found what i thought was a bad tranny, but ended up being a blown up TO bearing. SO, new axle in, new TO in, and my 2-piece driveshaft in the garage, i broke it apart, and not having the "blue" teflon lube, I just packed it with marine grease. Put all together, and with new diff fluid/tranny fluid in, i cruised the streets. Not wanting to "get on it", i parked it for the night..(this was last night..9/9/13). This morning ( 9/10/13), i said...F-IT, 6am, time to take daughter to school (45miles away)...good ol' divorce. Anyway, once grabbing 4th-5th....i noticed, NO MORE HOWLING SOUND. Man, should've seen the look on my/our faces. It was GREAT to finally, not have to talk over sound nor radio..(to drowned out the howl)....SO, in conclusion, i can not definitively state what one/s cured it, but from a new/used axle, greased splined driveshaft and new TO bearing, truck sounds AWESOME....
side note.....DAMN EFFIN TWEEKERS, last thursday night, caught me slip'n, and with everything apart, truck on stands, and batteries disconnected, found that my doorlocks were, well, not locked
. Got my radio and ripped thru my glovebox and console...Just finished up about an hour ago, installing a cheapo DUAL radio (40 buks) from Wallyworld...gotta have some type of tunes, right?
Tweekers... the second to go in the zombie apocalypse (the first to go will be the politicians and greedy rich that got us there).
