What's causing this horrid sound?
Old Dec 17, 2010 | 10:03 PM
2006powerstroke90's Avatar
2006powerstroke90
Well my turbo seems to make a nasty "woosh" sound figured I would check all connections to the turbo up pipe and down pipe. The sound will only happen when the turbo spools up then when I let off it's a woosh sound. Turbo spools great and whistles great.
I took the up pipe clamp off and it was sealed up perfectly. No gap anywhere around the whole connection. Put the clamp back on nice and snug.
Checked my down pipe all sealed great no gap anywhere around the connection.
Any ideas?? Thanks
Old Dec 17, 2010 | 10:29 PM
_Me2_'s Avatar
_Me2_
No bypass valve in these trucks, so the built up pressure has to escape through the intake.
Old Dec 17, 2010 | 11:56 PM
lakewood's Avatar
lakewood
Are you under hard acceleration? or towing hard when you let off. Or normal driving?
Old Dec 18, 2010 | 06:09 AM
2006powerstroke90
No load or towing. Just hard acceleration
Old Dec 18, 2010 | 08:23 AM
Ford_Doctor's Avatar
Ford_Doctor
Originally Posted by 2006powerstroke90
Well my turbo seems to make a nasty "woosh" sound figured I would check all connections to the turbo up pipe and down pipe. The sound will only happen when the turbo spools up then when I let off it's a woosh sound. Turbo spools great and whistles great....
Classic turbo flutter concern. As described the turbo is building boost (excessively) in the charge air cooler, tubes and intake manifold that rushes back out of the intake on deceleration. This is an indication that your turbocharger is sticking or stuck. Your turbocharger requires servicing. I also want to caution you that when this condition exists on trucks with older calibrations head gasket failures are more likely to occur particularly when towing. Have this condition properly diagnosed and corrected immediately.
Old Dec 18, 2010 | 08:27 AM
2006powerstroke90
Is this something I can do myself? Or should it go to the dealer?
Old Dec 18, 2010 | 08:49 AM
Jigger2020's Avatar
Jigger2020
If you have to ask you should take it in...
Old Dec 18, 2010 | 08:51 AM
2006powerstroke90
Just when I thought I was done putting money into the truck.
It's just the turbo that needs servicing?
Old Dec 18, 2010 | 09:00 AM
Zmann's Avatar
Zmann
there are multiple how to articles on turbo reconditioning assuming the actual turbo is the issue I would try it myself first
Old Dec 18, 2010 | 09:02 AM
Zmann's Avatar
Zmann
Diesel Technician Society
Old Dec 18, 2010 | 09:03 AM
2006powerstroke90
Well it never made the noise until I took the turbo out to do the egr delete and oil cooler
Old Dec 18, 2010 | 09:15 AM
Zmann's Avatar
Zmann
you should have mentioned that little tid bit sooner IMHO
Old Dec 18, 2010 | 01:43 PM
2006powerstroke90
Is it something I could have put together wrong?
Old Dec 18, 2010 | 04:16 PM
High Binder's Avatar
High Binder
Did you take the turbo apart?
Old Dec 18, 2010 | 04:25 PM
Zmann's Avatar
Zmann
no loss of boost?
