it would be really easy to wire up with the key off, you could either tap the factory anti theft light, or you could wire a relay up to the ignition running pin 87q to the light, so when the ignition was off the relay was activated.
Relays are fun.
tapping off of the factory theft light has a lot of merit...but where is that wire located and how do you identify it?
I'm sure if no where else you could locate it quickly by removing the cluster. On my pathfinder it was a separate light so it was much easier to locate.
I believed the hype so I bought four for my f250. Put them in all doors. Walked out of the office today and found the drivers side keyhole popped. Wiped me clean. was going to the deer lease this weekend.
Best 1st post and resurrection of a four-year-old-thread-ever.
