92 Ignition lock and key
Old Jul 13, 2007 | 07:58 AM
Chumbucket's Avatar
Chumbucket
I need to replace ignition lock and key on 1992 f150. Key busted off in cylinder. Anybody have directions to replace it?? Thank's
Old Jul 13, 2007 | 08:06 AM
quicklook2's Avatar
quicklook2
will the ignition turn with key in it?
if it does turn key to run, with battery disconnected, and insert 1/8" drill into hole on under side of steering column, pull out lockset, do not move anything, install new lockset.
if it does not move than do this. from ford manual:
-disconnect battery ground cable.
-remove steering wheel.
-using channel lock pliers or vise grips, twist lock cylinder cap until it seperates from the lock cylinder.
-using a 3/8" diameter drill, drill down middle of ignition key slot approx. 44mm (1-3/4") until lock cylinder breaks loose from breakaway base of lock cylinder. remove lock cyl. and drill shavings from the lock cylinder housing.
DO NOT DRILL TO DEEP!
-remove retainer, washer, ignition switch and actuator. thoroughly clean drill shavings and all other foreign materials from casting.
-carefully inspect lock cyl. housing for damage from the above operation. if damage is apparent, housing must be replaced.
install your lock cylinder.
good luck!
Old Jul 13, 2007 | 08:15 AM
Chumbucket's Avatar
Chumbucket
With a screwdriver
Old Jul 13, 2007 | 08:19 AM
quicklook2's Avatar
quicklook2
turn it with screwdriver and follow the first removal instructions.
you can get a lockset anywhere, and if you take the old lockset to a locksmith he can remove key piece and rekey the new lockset to match doorkey.
Old Jul 13, 2007 | 08:38 AM
netscaner's Avatar
netscaner
I bought a lock cylinder a few weeks ago for my 1986 E350 at Autozone for $ 9.99.
threepiece
May 26, 2016 08:03 PM
Tedster9
Jan 27, 2015 12:35 PM
aveluca
1983 - 2012 Ranger & B-Series
Mar 18, 2014 07:55 AM
BruteFord
Dec 22, 2013 09:53 AM
