02 Excursion
Old Oct 18, 2011 | 10:12 AM
Voodiloquist's Avatar
Voodiloquist
02 Excursion
Howdy Folks --
I am new here and this is my first post.
02 7.3 Excursion, 140K miles, lots of off road use, new ball joints at 135K.
I can hear a metal-to-metal thunking noise when going over bumps, no matter how small the bumps are. The noise is from the front. I put the vehicle on a lift and noticed the following:
The rubber bushings are shot on the following components:
steering damper, both stabilizer links and the stabilizer bar.
I found the parts -- the entire part only, not just the bushings.
Both bump stops are gone.
Questions:
Do you have to replace the entire part even though the bushings only appear perished?
Does the suspension have to be unweighted to R/R these parts?
Thank you in advance for any information. Also, any lessons learned pertaining to this repair are welcome.
Thanks,
voodiloquist
Old Oct 18, 2011 | 10:26 AM
samw57's Avatar
samw57
It sounds a lot like what is happening to my same X. i have a 2002 7.3L and my sway bar link arm bushings are gone. When i first heard the noise i sprayed some white lithium grease on them and it went away for the time being now i just need to replace them.
More Information for DORMAN 905301
myblkex
Apr 2, 2009 06:27 PM
afonda
19
Feb 4, 2009 01:03 PM
earl964
Mar 30, 2008 01:36 PM
Exploder02
Feb 17, 2006 02:44 PM
Msp541
Aug 9, 2004 02:49 PM
