Less Power and slugish when cold please help
Old Oct 14, 2011 | 08:07 PM
teri1980's Avatar
teri1980
I got my first diesel about 4 months ago and love the truck, but the truck milage has seemed to go down, and seems like I am blowing out white smoke. The turbo will fart every once and awhile and if I step on the truck ,takes a long time to get rpms up then just jumps up. The truck runs great once it is good and warmed up, but is a dog when it is cold jerky and no throttel response. No mods. Any help would be great.
Old Oct 14, 2011 | 09:08 PM
NewToDiesels's Avatar
NewToDiesels
What year is truck? Done any work on it? How many miles on it?
Old Oct 14, 2011 | 09:45 PM
bismic's Avatar
bismic
codes?
Does the white smoke smell like diesel or coolant?
Losing any coolant?
Old Oct 15, 2011 | 09:54 AM
teri1980's Avatar
teri1980
truck is an 04 with 155,000 miles, no coolant lose runs good when it is warmed up. Its just wierd if I leave the truck sit and step on it's really slow to reach high rpms then just jumps like turbo isn't winding up quick enough. I am just new to diesel and want some info before I take it to a shop don't want to get scamed no codes or lites only mod is 4 " magnaflow exhaust no chips.
Old Oct 15, 2011 | 10:02 AM
NewToDiesels
When you say no codes, did you use a scanner? The CEL doesn't have to be on for it to have codes stored.
I recommend starting with the FICM test that is listed in the tech folder at the top of the page when you initially get to the forum (it says read first).
You just need a #20 torx bit, a voltmeter, and someone to turn the key.
There is no magic answer for the issue you describe. It could be several things that need to be eliminated. One step at a time.
Old Oct 15, 2011 | 02:30 PM
djanzen's Avatar
djanzen
you do know these engines are derated until they
are warmed up?
Old Oct 15, 2011 | 02:33 PM
djanzen's Avatar
djanzen
sorry I only read the title the first time, you probability have bigger issues.
Old Oct 15, 2011 | 03:00 PM
BLADE35's Avatar
BLADE35
If you had some gauges you could run thru a bunch of stuff quick
I use a scangauge great unit for 160.00
Old Oct 15, 2011 | 04:15 PM
95PSDieselP's Avatar
95PSDieselP
What does the scangauge do exactly? is it like a bunch of gauges in one computer thing instead of buying all them gauges for the truck???
Old Oct 15, 2011 | 04:23 PM
BLADE35's Avatar
BLADE35
EXACTLY
you will have 40-50 possibilities depending on year/pcm stratigy
it will store 24 or so gauges just program the ones that you want
Its a GREAT Unit for 160.00 check it out
www.scangauge.com
Old Oct 15, 2011 | 04:27 PM
95PSDieselP
Pyro and stuff as well???
Old Oct 15, 2011 | 04:32 PM
bismic's Avatar
bismic
You don't have a temperature gauge for the EGT so, no, it won't read EGT (pyro). Similarly you don't have a fuel pressure transmitter - unless you have added one.
Old Oct 15, 2011 | 04:33 PM
BLADE35's Avatar
BLADE35
The SG only sees what the PCM sees
so there are no factory senders for EGT,Fuel Pressure so you have to start from scratch on those
Like Edge insight has an expansion port for those IIRC but doesnt get neer as many gauges as ScanGauge does
With a SG and EGT,Fuel Pressure on the pilliar or whatever you have the truck pretty well covered
Old Oct 15, 2011 | 04:45 PM
95PSDieselP
Thank you for the VERY useful information sir.
IHATEFORDS1990
Dec 6, 2017 09:38 AM
afmedic
Jan 19, 2016 03:37 PM
Skinner F350
Jul 6, 2015 07:20 PM
Calpwrstroke
6.4L Power Stroke Diesel
Feb 2, 2012 06:23 PM
BekooyCh
Nov 13, 2005 12:45 AM
