man your HPO system is the style that usually the pump fails but not much eles
so you just feel the air around the #1 injector where the oil rail goes into the top of the injector
could be a bad injector just letting the oil go thru it
LOL--I guess you didn't see the injector pic Benny. He had a d-ring blown out of the top of his injector. Hopefully when he gets that replaced he can retest and find out that's his only problem.
Steve--Your standpipes are different and you don't have dummy plugs in the HPO rails. That upgrade doesn't apply to your truck.
You mentioneed that you still hear air from around injector #1 after replacing the oring
the top oring has been replaced on that injector so we know that one is good
but I wonder if the Injector itself is bad on the oil side of the injector could be that the spool valve is stuck open just letting Air/oil run thru it
since I have all the injectors out I am going to put them back in reverse order. If the sound moves to the back of the engine then I can assume that it is the injector which was #1 and is now #7
since the injectors are out maybe you can just take the one injector in question and blow air into it at the top hole and see if it bleeds out the oil drain on the side of the injector
