5 speed shifter removal
Old Oct 13, 2011 | 10:42 PM
statetrooper's Avatar
statetrooper
Hi this is my first thread and i would like to know how to get the shifter off the top of the transmission ,there is a threaded bolt that goes through the end of the shifter with a nut on ,how do you get the bolt out, i need to remove to take transmission out to replace the clutch
thanks
Old Oct 13, 2011 | 10:59 PM
Ed Bamba's Avatar
Ed Bamba
Remove the nut and thread onto the other end of the bolt. As you tighten the nut, it pulls the bolt out. Providing this is an M5OD transmission.
Old Oct 13, 2011 | 11:17 PM
statetrooper
shifter removed
thanks easy once ya know how
Old Oct 14, 2011 | 12:29 AM
SideWinder4.9l's Avatar
SideWinder4.9l
It should have 2 nuts on it (Hahaha)....One tightens the "Bolt" (Its more of a tapered dowel pin)....And the other loosens it up...
Btw...Make sure its in Neutral before removal.....
Old Nov 4, 2014 | 06:48 AM
HD Fatboy's Avatar
HD Fatboy
I know this thread is old
I know this is an old thread, but as stated in the above posts, I removed the bolt at the base of the shifter, and it is still stuck to the stub. Has anyone have this happen? I have been trying to remove the shifter now for three days, sprayed it down a lot with PB Blaster still will not come off. I am concerned about using heat.
Thanks in advance.
Old Nov 4, 2014 | 08:29 AM
jas88's Avatar
jas88
You do not have to remove the shifter lever from the stub, you could just take the 3 bolts out of the cover and remove the entire thing.
Old Nov 4, 2014 | 09:03 AM
HD Fatboy's Avatar
HD Fatboy
Thanks for the quick reply. I will try again tonight after work. The thing I think I am remembering is 1 of the 3 bolts is directly under that knuckle area the bolt goes through so I am not sure I can get a tool on that bolt.
Old Nov 4, 2014 | 02:41 PM
Diesel_Brad's Avatar
Diesel_Brad
fatboy. Do you have a F150, f250, F350, etc.
Fill out your signature so we know what truck you have
Old Nov 4, 2014 | 03:09 PM
HD Fatboy's Avatar
HD Fatboy
F150 XLT lariat 3.9 V6
Old Nov 4, 2014 | 03:59 PM
HD Fatboy's Avatar
HD Fatboy
The three bolt removal worked. Thanks!
Old Nov 4, 2014 | 06:12 PM
Diesel_Brad
An 82/83? because those were the only years to have them from the factory
Anthony Pantoja
Apr 30, 2017 01:03 PM
vegas5701
1997 - 2003 F150
Mar 7, 2016 07:35 PM
jim collins
1983 - 2012 Ranger & B-Series
Feb 15, 2012 05:09 PM
mrblonde108
Apr 11, 2011 10:13 PM
fcmtnbiker
Jan 15, 2011 11:12 PM
