Sponsored by: Auxito
Manual Shifter Removal
Old Mar 5, 2016 | 03:06 PM
vegas5701's Avatar
vegas5701
Trying to remove the shifter on my 97 F150 XLT 5.4L 4x4, but I've run into a problem. I understand that after removing the boot, you unthread the nut on one side and put it on the other to pull the shifter retaining bolt out. My problem is the nut is MISSING. I've been to multiple parts stores and Ford's part dept to try and find out the thread and nut size of that nut. No luck.
Do you know what size that nut is?? OR, is there another way to get that retaining bolt out of the base of the shifter without the nut?
Thanks.
Old Mar 7, 2016 | 07:19 PM
steve(ill)'s Avatar
steve(ill)
you may want to remove the entire unit, then work on the bolt.
https://www.ford-trucks.com/forums/1...-write-up.html
Old Mar 7, 2016 | 07:27 PM
vegas5701's Avatar
vegas5701
It's actually for the manual transmission shifter.
Yesterday I went to the hardware store and bought 6 nuts of varying size and thread. One of them felt like a perfect fit...but when I got the bolt out I can see I shaved some of the threads. Looks like I'm going to have to replace the bolt. On the bright side now I can figure out the right nut size with the bolt out! One step back and one step forward!
Thanks for the reply.
Old Mar 7, 2016 | 07:31 PM
kd4gij's Avatar
kd4gij
It is most likely metric.
Old Mar 7, 2016 | 07:35 PM
vegas5701's Avatar
vegas5701
The nut i thought fit was a 12-150, but it needed a highr thread count. So far everything on the drivetrain has been metric.
Anthony Pantoja
Apr 30, 2017 01:03 PM
statetrooper
Nov 4, 2014 06:12 PM
fcmtnbiker
Jan 15, 2011 11:12 PM
firsttimeford
Feb 7, 2004 01:51 PM
wekims
1983 - 2012 Ranger & B-Series
Sep 8, 2003 09:35 PM
