'92-'96 instrument clusters
Old Nov 4, 2014 | 01:48 PM
Old Primer Red's Avatar
Old Primer Red
I have a '95 Eddie Bauer F150 with just the speedo and two Gage's on each side. Will the instruments with the tachometer swap directly into my truck? And is there a way to swap my odometer reading into the other instrument cluster if they will swap?
Old Nov 4, 2014 | 05:32 PM
spacegrass's Avatar
spacegrass
They will*, technically. For the odometer reading, you'll have to swap your PSOM (which you'll find out about below).
*Your best bet to avoid having to swap pins on the connectors is find one from the same year (1995 in your case). I can't find it with a quick search, but theres a thread out in the wild internets with replys from a guy named Steve83 (who is one of the most helpful people in the universe). In it, you'll find not only which clusters are direct swaps (by year) but also what pins to change if you have one off a different year.
EDIT
Ok, 94-96 is plug and play and here is where you'll find info on the PSOM swappage.
Old Nov 4, 2014 | 07:51 PM
abranz's Avatar
abranz
Here's the link with the pin outs and what needs to be changed. I just swapped a 94 cluster into a 93. I had to swap a few wires, nothing big. https://www.ford-trucks.com/forums/1...eedometer.html
Gichael
Apr 26, 2017 07:02 PM
velcro7279
Oct 13, 2013 09:24 AM
hush210
1997 - 2003 F150
Feb 23, 2007 08:37 PM
truchafuego
Feb 25, 2005 05:07 AM
Phobia16V
Nov 16, 2003 10:41 AM
