Well i gave up using the search feature on this forum and a couple of others as they all stink. So here it is, my question. I know i can remove the torx head screws and lift the shifter up out on the 5 /speed transmission. But it's under the removable cover i wanted to leave alone. There is a large,maybe 1/2 inch bolt at the lower part of the shifter. If i remove it will the shifter come off ? All i want to do is get the shifter and boot out of the way so it will be a little easier to install some new carpet. I can see why so many things come up over and over because like i said, "search " stinks. I have tried all of the suggestions that others have told me to try,never works...Well I'v vented enough,time to get back to it.
Reason: corrected spelling
Thanks, I thought it might work that way, but since the ranger is new to me, I thought I had better check before I mess something up. Not made any thing like the old F-series trucks that I work on most of the time.
