Replacing window regulator...
Old Oct 13, 2011 | 11:56 AM
1986F150six's Avatar
1986F150six
This past weekend, I replaced a wornout window regulator in a 1984 F150. It is not a difficult job. For those contemplating doing this, the three factory rivets can be replaced with 1/4" by 1/2" long bolts with a lock washer and a locking nut. That is just the right length with no interference with any moving parts.
It surely is nice being able to raise the window without binding!
Old Oct 13, 2011 | 03:05 PM
TheKirbyMan's Avatar
TheKirbyMan
What kind of drill or tool did you use to remove the rivets? I've been wanting to convert to power windows for a while now and I have a Dremel, but I'm not sure how to go about drilling out the rivets.
Old Oct 14, 2011 | 05:34 AM
1986F150six
Take a hammer and strike the rivet. This will force the steel pin to exit out the rear or at least be flush with the rivet. Next, take a punch and force the pins out. They will drop to the bottom of the door and can be retrieved with a magnet or your fingers. Finally, use a 1/4" drill bit [or 3/8", just be careful not to drill throught the door].
It's easy!
Old Oct 14, 2011 | 06:29 AM
locknkey's Avatar
locknkey
The easiest an safest way is to drill them out, very simple to do, and you can replace the rivets as well, Sears sell a pop rivet gun with all the pop rivets, all you have to do is drill,remove old pop rivet an replace with new ones...this isn't hard to do. Why take a chance at hammering the metal inwards? Drill an replace the pop rivets, these are DESIGNED to be removed this way.
Old Oct 14, 2011 | 08:30 AM
ctubutis's Avatar
ctubutis
I would replace them with nuts & bolts; the factory uses rivets because they're faster to use on the assembly line, not because they do a better job of holding things together than nuts & bolts do.
I would personally first want to knock the pins through, it's that much less to drill through and the remaining material is soft aluminum.
Old Oct 14, 2011 | 07:32 PM
locknkey's Avatar
locknkey
Pop Rivets are quicker to install and will not interfere with the installation of the door panels. They are easy to drill out with a slightly undersize drill bit and you do not have to go all the way through the sheet metal. You have your way, and I like to do things the way they were designed for from the factory, after all...they have held together this long and with nuts an bolts to contend with there isn't any likely possibility of them becoming loose in the future using pop Rivets....if he decides to use nuts an bolts, he'll find out just how "ez" they are to install the door panel (they will rub through) and get loose over time....
Old Nov 17, 2016 | 04:39 PM
johntmcdonald's Avatar
johntmcdonald
I have a similar problem bit with one rivet sheared. The hole has now out of alignment and it is a "bear" to get it to move. I have not been able to do so. Am I going to have to remove all rivets and replace after realigning???
thanks
Old Nov 18, 2016 | 10:17 AM
WhatsAChevy?'s Avatar
WhatsAChevy?
thanks
You are going to be in there anyway....why not replace them all.
Old Nov 18, 2016 | 02:07 PM
WhatsAChevy?
Over the years at the dealers that I worked for, the techs did it the exact same way, even under factory warranty repair orders. For a few years GM had a rash of crappy window regulator motors and it was common for the techs to have to replace the regulator/motor assembly numerous times so the nuts-n-bolts approach proved better for serviceability. Glad you got it squared away.
Old Nov 18, 2016 | 02:25 PM
SVTDriver97's Avatar
SVTDriver97
I already did a write up on this a few years ago:
https://www.ford-trucks.com/forums/1...ow-motors.html
Old Nov 18, 2016 | 04:57 PM
WhatsAChevy?
Good to know....still good to hear other's experiences though.
lafermedavid
Aug 4, 2017 04:53 PM
paintinpevs91
Jul 18, 2012 10:52 PM
CalebJns
Sep 21, 2010 02:55 PM
AirborneRanger
1983 - 2012 Ranger & B-Series
Jul 15, 2005 02:12 AM
YWAMNick82f150
Nov 25, 2002 10:46 PM
