window regulator
Old Aug 4, 2017 | 12:53 PM
lafermedavid's Avatar
lafermedavid
window regulator
Im swapping hardware from older door to new door,for all who have experience,do I just grind these off to remove regulator,as of now the only thing holding it in,,,,And what did you use for replacement ? Thank you in advance
Old Aug 4, 2017 | 12:55 PM
scottscott's Avatar
scottscott
I drilled the rivets out, & replaced them with small bolts & nuts.
Old Aug 4, 2017 | 01:31 PM
lafermedavid
Thanks Scott
Old Aug 4, 2017 | 02:00 PM
72rtchallenger's Avatar
72rtchallenger
Something like that I might just use new pop rivets
Old Aug 4, 2017 | 03:01 PM
wyrm73's Avatar
wyrm73
IIRC, the rivets big enough for a window regulator require one of those monster, long-handled rivet guns, not the cheap little Pop-Rivet ones you buy at Home Depot. I had to do the same type of swap years ago and the local glass shop only charged me a couple bucks to do it instead of buying the tool.
x2 on drill them out instead of grinding.
Old Aug 4, 2017 | 04:40 PM
PapaBearYuma's Avatar
PapaBearYuma
I changed the regulator in the brown truck a while back. Just drill out the aluminum rivets with a 1/4" bit. The regulator I bought came with rivets, but you need a special rivet tool - they're expensive!
I installed the new regulator with nuts, lock-washers and bolts.
Applied some white lithium grease to the new roller before I buttoned it all back up.
Old Aug 4, 2017 | 04:49 PM
lafermedavid
I just pulled all the guts out of my old door,cleaned lock with oven cleaner,,,,thought I would be able to use wing window rubber,but with further inspection rust build up under rubber,shipping my wing window frame out to be blasted and powdered,(protected)one window at a time,,,thanks for all help,,,I guess Ill be using small bolts and nuts for window regulator....I do have one of those tools that puts a threaded insert compressed ,I maybe able to install that on the regulator and install 1/4 x20 bolts ,,,sorta tapped
Old Aug 4, 2017 | 04:53 PM
72rtchallenger
This one does 1/4" rivets 5 in 1 Heavy Duty Hand Riveter Pop Gun Rivets 1/8" 5/32" 3/16" 7/32" 1/4" sizes
I think that is big enough for the window regulator but unsure
1986F150six
Nov 18, 2016 04:57 PM
paintinpevs91
Jul 18, 2012 10:52 PM
CalebJns
Sep 21, 2010 02:55 PM
batboy
Jun 15, 2003 10:04 PM
YWAMNick82f150
Nov 25, 2002 10:46 PM
