stupid rotted brake lines
Hi all,
Is it a do it yourself job to replace brake lines. Never done it before or even seen it done. Special tools required? Will the auto parts store know exactly what I need? Are these questions answering my question?(don't do it)
Sort of handy and might have someone with more knowledge about this than me available for guidance.
Thanks in advance for your knowledge.
I've not done this on an Ex, but on other vehicles. It's not difficult, just takes time. Being **** is better than doing a fast, sloppy job. Drain as much as possible of the fluid from the system (it easily removes paint), shape your new brakeline to exactly match the removed piece, flair (put the nut on first - doh) the ends (special tool is needed - they can be $40 to $400) and move on to the next section. Part store will have these in standard sizes, but the Ex might need a longer section. Didn't someone post a brake line supplier recently here? Certainly not a high-tech job. Bleed the brakes when done. Why not R&R the master brake cylinder while everything is apart? Then you're sure of no future issues. I used steel lines and painted them with a brush (to keep the rust down) after assembly.
Thanks for the replies. Yes steel but will check the rubber while under there. And I would rather err on the side of **** rather than rush, just no need. Have not seen what exactly the problem is as my son has the truck and is 200 miles away but will look into the issues this weekend. Can only hope for weather like last weekend!
1. Buy the brake line from these folks in Atlanta. It never rusts, bends easier than steel, and is fully DOT approved. It is about the best you can get. Copper/nickle alloy. More expensive, but you never have to worry about them again. I am putting this under my truck during this winters upgrades.
Federal Hill Trading Company
2. Get these bending tools as a set. Pretty much does it all.
Tubing Bender and Forming Pliers Kit - Tubing Bender Pliers - Pliers for Tubing
3. Shop around for a double flare tool. The Sears Craftsman and the Ridjid units have a good reputation.
Amazon.com: Ridgid 23332 Flaring Tool: Home Improvement
I have this one and it works real good, but pricy as hell. I figured I would pay less for the tooling and line to put things in myself in one vehicle than I would have to pay a shop to do it. And I get the tools to keep, so I spent the money.
Amazon.com: K-Tool International (KTI70081) Brake Pipe Flaring Tool: Automotive
Go to Bronco Graveyard
Early Bronco Restoration Full Size Bronco Restoration Classic Ford Bronco Parts For Sale
Order a set of pre-bent Stainless Steel Lines. I know Rust Living in Erie PA, all I see in Winter is Salt Salt and more Salt
only thing i needed to do for my 1993 F150 4x4 was go to Advanced autoparts for a Adapter. only one of the fittings was wrong.
Other than that it was the eaisest thing in the world to do and no more Rust to worry about and Pedal feels 100% better
Well my son took the truck to his voc school (towed it -love AAA) and the future mechanics of America replaced lines, rotors, pads, calipers, e-brake cable, and on and on and on so I still have no experience replaceing any of that stuff but they did a great job and for short $$. Thanks for all the replies.
The pliers are nice but you can crimp lines with them if you try to bend too much with them - it will also nick the line a bit but it isn't a huge deal. For the brake line - I recommend the copper nickel line. It's soft enough to get nice bends with and it flares easily with most tools.
Nevermind, got off my lazy butt and searched. Here is one place:
