2000 7.3 replaced the pedistal o rings its still leaking just not as bad i need help what to do i just took everything back apart tonight to find no trouble the leak is comming from nxt to the starterl. it has a hyper max turbo on it also. please help
Sure its not the HPOP lines on top going down the valley and thur the hole on passager side and then accross the starter. It could be o-rings in the HPOP lines if not thte turbo. Chet
Welcome to FTE.As mentioned above,it sure could be the braided hoses leaking.Not the actual hose but the inner or outer orings.There is a plug on the bottom of the HPOP that Ford calls ''non-servicable''.It is servicable and Clay or Bob(Guzzle)sells a kit.Did you change or delete the the seal on the pedastal?
Since you did not find a smoking gun when you took everything apart again you may need to re-install,clean everything up good,run the truck and keep an eye out for the leak.
Good luck!
hey guys im in plainfield il
there is no oil in the valley at all i put everything back togather even replaced the orings again to be sure and i still have a good drip from somewhere ! if i look in the valley down by the braided lines everything is dry! im not sure where to go from here guys! please help me ! and it is still coming from next to the starter!
If it is for sure oil and not diesel....I know...had to ask.It has to be the rear main oil seal.You have looked over evrything on top that could leak oil.We do not usually see rear main oil seal leaks.Mine leaks at the rear main,it keeps the dust cover oily and usually leaks about a quart every 5000.
its not the rear main(it was done by perivous owner) and it is not fuel ! should i tighten my vavle covers? do you think that the vavle cover would cause a constant drip when running? im clueless
Check around the one on that side. Wipe around it and see. Check the hole in the valley and see if theres oil there, by the fire wall. Theres not to many places it could be coming from. Turbo pedistal, turbo, HPOP, valve cover gasket on the starter in fact if it ain't fuel. Good luck, Chet Post where you are, maybe a member can help you look if there close.
yeah in im plainfield il, the turbo setup is completely differnet from a stock turbo there is no oil coming from the turbo though or pedistal thanks for all you help so far guys!!!
