E-brake/parking brake improvements?
Thanks MK2
That is very insightful and that is a great solution for the crappy oem ebrake set up. It may not be a solution for a parking brake but for winching or launching a boat it is a great solution. So this now on my wish list or should I say parts to buy list.
Now where you mounted your makes alot of sense but I would have thought you would have issues bleeding the ABS pump and brakes. I thought there was a special way you had to bleed the ABS pump? Was that a issue for you?
The way you have it wired sounds like a sweet set up also.
Do you have any photos...please.
That is very insightful and that is a great solution for the crappy oem ebrake set up. It may not be a solution for a parking brake but for winching or launching a boat it is a great solution. So this now on my wish list or should I say parts to buy list. Now where you mounted your makes alot of sense but I would have thought you would have issues bleeding the ABS pump and brakes. I thought there was a special way you had to bleed the ABS pump? Was that a issue for you?
I'll take pics of the setup when my EX comes back to me. My dad borrowed it for a hunting trip cuz it pulls his TT smoother than his gas 2500HD
scottperkins
2009 - 2014 F150
Jul 15, 2014 08:22 AM
BigBadPowerstrok
Nov 13, 2007 01:32 AM
