Throttle issues 2000 F350
Old Dec 9, 2014 | 12:02 PM
Beachdvm's Avatar
Beachdvm
I have a 2000 F350 dually that has been acting up. At an idle, it will sometimes die, and on the highway when maintaining speed, it will cut out and surge sometimes. It seems to be the worst at a certain spot on the throttle but I'm not sure if it would be the TPS, or somewhere else.
Old Dec 12, 2014 | 11:20 AM
Beachdvm's Avatar
Beachdvm
Any ideas on where to start?
Old Dec 12, 2014 | 12:52 PM
Shake-N-Bake's Avatar
Shake-N-Bake
If you have cruise control. Try setting it at the certain speed and see if the symptoms return. If the truck runs fine on cruise but glitchy with the pedal then you might want to investigate the throttle position sensor and idle validation switch.
Also check to make sure the stamped tin nut on the IPR is nice and tight. Sometimes those things come loose and fall down into the engine valley and cause the symptoms you describe.
Good luck.
Hogtrapper
Modular V10 (6.8l)
Feb 21, 2013 06:34 AM
bcaughhorn
20
Mar 11, 2011 09:19 PM
Maxium4x4
Apr 23, 2010 11:09 AM
HTi-Enright
Jan 7, 2008 07:14 AM
Catfish_Man
All Things Towing
Nov 9, 2005 03:54 PM
