Sponsored by: Real Truck
Clearance Light Harness Question
Old Oct 5, 2011 | 10:15 PM
nghtrgr's Avatar
nghtrgr
Bought a set of used Ford Clearance lights on ebay....everything is in very nice condition. The harness that came with it does not have the square plug that I have seen in install pictures but rather a round plug with gray housing, in addition there is another plug that has a yellow connector with what looks like a BNC/Coax type connector. Is this normal??? What is the yellow connecter for??? Antenna or something for the overhead pod?
Old Oct 5, 2011 | 11:04 PM
BigAlsPSD's Avatar
BigAlsPSD
Generally a connector like that and being yellow would be for Airbag stuff, I'm no help, essentially a bump for you.
Old Oct 5, 2011 | 11:50 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I have never seen one like that. ???
Does your Ex have the overhead console? If so, then you are good. Just follow the wires to the connector in the right kick panel. Disassemble your existing plug as well as the plug on the harness for the lights. There should be two vacant spots on your existing plug. Use a test light to see which one is power and which one is ground. Than insert the wires (with terminal ends) into the associated vacant spots on the original connector, replace the red locking blade and plug it back in.
Only little issue will be that the console harness will already be using the holes for the grommet pins so you will need to route the clearance light harness along side the console harness and secure with some electrical tape or little zip ties.
Old Oct 6, 2011 | 12:12 AM
TexasRebel's Avatar
TexasRebel
2008 has a round plug for the clearance lights... I'm guessing '09 and '010 do, too.
no clue what the BNC connector (if it is as you described it) is for... Satellite radio maybe? Navstar?
Old Oct 6, 2011 | 02:00 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
pictures of setup?
Old Oct 6, 2011 | 03:04 AM
twags6's Avatar
twags6
Antenna connector for a NAV system?
Old Oct 6, 2011 | 05:01 PM
nghtrgr's Avatar
nghtrgr
I'll post some pics later.
Old Oct 6, 2011 | 07:00 PM
nghtrgr's Avatar
nghtrgr
Here are pics of the plugs the yellow one had the sticker. Anyone see these on clearance light harness before???
Old Oct 6, 2011 | 07:22 PM
TexasRebel's Avatar
TexasRebel
The grey connector looks normal... same thing that was on my pickup.
no clue what the yellow one is... coaxial cable, so I'm guessing an antenna of some kind. Coax is used to transmit signal, not power. That blue mess behind your hand looks very un-OEM to me...
Old Oct 6, 2011 | 07:58 PM
nghtrgr's Avatar
nghtrgr
Blue mess is a Ford sticker on the harness, I have no doubt its OEM just wondering what the coax goes to or went to
Old Oct 7, 2011 | 12:42 AM
PowerStrokeHD's Avatar
PowerStrokeHD
Looks like what should be two separate harnesses from a '08+. The tag that is pictured with the base part number of 19A397 goes with the yellow connector and is the harness for the satellite radio antenna. The round connector is the harness for the roof clearance lights and should have a base part number of 15A404.
microbc
Feb 3, 2017 04:15 AM
robd928
May 18, 2011 09:37 PM
smashclash
Jan 23, 2011 01:53 PM
DAFBFD58
Jul 7, 2008 11:10 AM
98x50
Mar 28, 2007 08:13 PM
