transmission question
Old Oct 5, 2011 | 04:23 PM
levimorris85's Avatar
levimorris85
The wife has an 03 6.0 Ex. what would cause the truck to "slip" going into second gear and then make the O/D light flash. If you put the truck in Netural and kill it, restart and back to drive it fixes the problem for a day or so....then same ol song and dance. Any ideas (ie. transmission shift position sensor)
Old Oct 5, 2011 | 08:14 PM
Fishing_Uncle's Avatar
Fishing_Uncle
Your sig says the truck has an Edge tuner? Can that pull the codes? I,m not familiar with that tuner but figured I'd ask.
Old Oct 5, 2011 | 10:12 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
When the tow/haul light (there is no OD light on a 6.0L truck) flashes a code is stored in the PCM. It will still be in memory even if the light isn't flashing any more. You need a high end scanner to read Ford transmission codes.
Without the code just start buying parts hoping to find the right one.
Old Oct 6, 2011 | 09:06 AM
levimorris85
Extremely long story short, The edge isn't on there. but even when it was i never read how to pull codes with it.
Hey T. I may be calling you in a day or two.
Old Oct 6, 2011 | 10:19 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Not to hijack, but as in me?
Old Oct 6, 2011 | 10:36 AM
Fishing_Uncle
Got ya Levi, just thought maybe you might have overlooked that.
Hope you get it figured out.
Old Oct 6, 2011 | 04:31 PM
levimorris85
Thank yall. And yes toreador you.
Old Oct 6, 2011 | 04:34 PM
Toreador_Diesel
Figured....you must've known I was watching.
Give me a call and we'll make arrangements...
Amicus
Mar 31, 2017 11:53 AM
Sondre Næss
Mar 14, 2017 10:45 AM
sprinklers
39
Mar 28, 2015 08:18 PM
F350long
Oct 1, 2007 09:14 AM
knocturnal
Dec 5, 2003 05:53 AM
