1982 Thermactor air pump broke - should I replace?
The belt driving my smog air pump broke this weekend on a camping trip. The vehicle is a 1982 class C motorhome with E-350 dually rig, 460 with a Carter carb. I think the air pump locked up, then the drive pulley ate through the belt. I had a replacement belt, but since I would've had to remove another belt or two I just got back on the road and did another 150 miles. The air pump is almost impossible to turn, so I think something's seized up inside. I figured the diverter valve would keep the exhaust gases out of the pump.
Looking up the cost of a new smog pump, it runs about $80. Should I even bother, since I'm in Wyoming and we don't do emission checks? If I did the replacement, should I replace the valve too? The rig has about 82,000 miles on it, and I think this is the original equipment.
Being somewhat lazy, I wasn't planning on taking anything out until I needed to. That is, as long as I won't get exhaust fumes back up the hoses.
I am assuming the thermactor is something like a sliding vane pump rather than a centrifugal fan - therefore it acts somewhat like a check valve too. True?
Thanks for the replies, redmond. Since I might be upgrading to a more modern motorhome in a few months (hope I get $$ bonus instead of a jelly-of-the-month-club subscription), I don't want to start tearing out smog equipment that a new owner might need. Since my van's engine doghouse isn't hermetically sealed by any stretch of the imagination, I just don't want to have exhaust fumes sneak back up the hoses.
I found a schematic that shows a Ford thermactor pump as a 3 vane sliding pump, but also found a few references to a centrifugal air pump design too.
04-26-2011 11:22 PM
BlueTorpedo85
01-29-2005 05:08 PM
