Locked up air pump
Old Jun 2, 2006 | 03:33 PM
BigGreenGiant's Avatar
BigGreenGiant
Locked up air pump
The air pump on my truck has locked up. I could replace it, but the costs seem pretty high. Is it possible to just remove this part? if so do I need to put the air hoses together with a coupling? What else can I do? Someone told me I could just put in a idler pully, but not really sure what that is. Thanks!
Old Jun 2, 2006 | 03:37 PM
andym's Avatar
andym
If you don't have emissions testing where you live, you can just get a shorter belt to bypass it. Use a string to measure the length around all the pulleys.
Do you have cats installed?
Old Jun 2, 2006 | 03:39 PM
BigGreenGiant
The air pump is in the way of a shorter belt, so I think i have to remove it. what is cats?
