manual transmission
Old Sep 28, 2011 | 09:09 PM
robdob57's Avatar
robdob57
manual transmission
Okay '87 f150 300 6cyl has a 4 spd would like to have this '91 5 spd i got will it bolt up to the bell housing for the 4spd and its prob longer so will have to get a diff drive shaft?
Old Sep 28, 2011 | 09:22 PM
peter_x's Avatar
peter_x
I think the 300 shared the same bell housing pattern as the 302 and 351. If it's from a 460 or diesel it's a no-go.
Old Sep 28, 2011 | 09:57 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Is the '91 an F150? If so, no matter witch engine it goes from, it's gonna bolt up.
Only 3 engines offered in that model for F150's, 300-6cyl, 302 and 351. All witch share the same bell housing bolt patern.
If it's from an F250HD or F350, it will be the better ZF5 heavy duty trans witch is MUCH better than the half ton Mazda tranny. Same rule applys, must come off a 300, 302 or 351.
Old Sep 28, 2011 | 10:51 PM
robdob57's Avatar
robdob57
tell me more about the ZF5 tranny like is it a 1st gear granny and not going to be like a overdrive in 5th to get better gas milage
Old Sep 28, 2011 | 10:55 PM
IDIDieselJohn
1st gear is really low, 5th gear is OverDrive.
Reverse gear is also very low.
Unlike the Mazda tranny, Reverse is very very tall, and it's hard on the clutch if your backing up a trailer with that tranny.
The ZF is the best you can ask for in the standard transmission world. Mine has 377k miles on it, and i've never touched it!
Old Sep 28, 2011 | 11:04 PM
robdob57's Avatar
robdob57
well my '87 is a swb fleetside that will prob never tow anything again i dont need a granny gear. so the mazda tranny is a bad choice for just driving? i dont know if the speedo on 87 is manual or electronic!
Old Sep 28, 2011 | 11:07 PM
robdob57's Avatar
robdob57
so you think a ZF5 from a f250 will bolt up?
Old Sep 28, 2011 | 11:46 PM
peter_x's Avatar
peter_x
Yes, unless the F-250 had a 460 or diesel.
Oh, and the ZF5 had 2wd and 4wd versions as well, so you need to match that too.
Old Sep 29, 2011 | 11:41 AM
IDIDieselJohn
If your not gonna tow anything, the Mazda tranny will be perfectly fine for driving around.
Both 87-91 have speedo cables so your good to go on that.
#1spudman
May 11, 2015 07:17 AM
mudder460
Jan 29, 2008 05:21 PM
tampabandit
Apr 18, 2004 01:55 AM
Superdave
Jul 8, 2000 09:01 AM
elsmith
May 6, 2000 02:29 PM
