help with hogs head or bell houseing
Old 05-10-2015, 04:48 PM
#1spudman
#1spudman is offline
#1spudman is starting off with a positive reputation.
i have a 1985 300 six will manual trans 4x4 eng but will the six cyl bell housing fit on a 302 or 351 eng i did have a 65 ford that someone did use a six cyl manual bell housing with a 351 eng but forgot to use a v8 fly wheel and nox out the rear main on it hope some one knows if this will work togather thanks for help i need all the help i can git #1spudman
Old 05-11-2015, 03:02 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
The 300-6 uses the same bell housing bolt pattern as the 302/351W. There are too many variations of parts used on different applications to say for sure if your parts are compatible with whatever you're planning too do, based solely on your description here.
Old 05-11-2015, 07:17 AM
#1spudman
thanks im thinking of pulling the 300 six out of my 85 4x4 and putting a 302 in its place if i need too it has a 4 speed with granny and like the keep the 4 speed trans thanks you for this info its a big help to me i have a 302 in my 51 ford truck have ben making a rat rod out of it thank you one more time #1spudman
#1spudman
09-06-2016 10:49 PM
#1spudman
07-25-2016 04:13 PM
#1spudman
08-04-2015 09:26 AM
#1spudman
06-03-2015 09:53 AM
#1spudman
06-19-2014 12:18 PM
Quick Reply: help with hogs head or bell houseing
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
