f150 cats
Old Sep 26, 2011 | 07:13 PM
fordsuperduty250's Avatar
fordsuperduty250
f150 cats
i have a 1993 ford f150 with the 4.9l straight six and a 5 speed. Right now my exhaust is right off the cats no muffler no tailpipe. Just manifold, and the 2 cats that are inline with each other. I am thinking about cutting off the rear cat so i will only have one. I want my truck to be louder and i think that will do it. Also will it be bad to run my truck with just the one cat and nothing else? will it hurt my mpg's? hurt the motor at all?
Old Sep 26, 2011 | 07:23 PM
Edgethis's Avatar
Edgethis
No It won't hurt your truck. Actually a member did just that.
https://www.ford-trucks.com/forums/1...planation.html
Theres even a video. he has a 351w, but you get the idea as to space and options.
Old Sep 27, 2011 | 01:39 AM
TexasGuy001's Avatar
TexasGuy001
While it wont hurt your truck, I'd leave it. The 4.9 sounds so much better with a mellow sounding exhaust than a loud one. No matter what you do it wont sound like a V8. That's not downplaying the I6 though.
Old Sep 27, 2011 | 09:41 AM
Kemicalburns's Avatar
Kemicalburns
i agree. if anything unhook the last cat and run about 3' of exhaust and install a flowmaster of some sort. this will give it a decent sound but you will never get the v8 sound out of that engine so why bother??
you have a good motor and being stealth has its benefits.
Old Sep 27, 2011 | 07:39 PM
TexasGuy001
The I6 doesn't move enough air for 3 inch exhaust. A good 2.5 inch is a better match.
Old Sep 27, 2011 | 07:41 PM
TexasGuy001
I recommend anything but the hollow tin can sounding Flownaster. I suggest Magnaflow or Dynomax Super Turbo.
Old Sep 28, 2011 | 10:22 AM
Kemicalburns
a 50 series flow wouldnt be bad.
Old Sep 28, 2011 | 11:27 AM
SCRebel's Avatar
SCRebel
You also might want to look at replacing the cat, if you think your old one is clogged.
Old Sep 29, 2011 | 05:43 AM
TexasGuy001
I had one and it still had the hollow can sound. Also, after looking inside of a 50 series or any of the larger mufflers, I don't see how they can flow well at all. The exhaust has to go through a maze to get out.
Old Sep 29, 2011 | 05:44 AM
TexasGuy001
I'd replace both cats with a good high flow one and a good muffler to finish it off.
FordNFishinLover
Exhaust Systems
Jul 27, 2009 10:03 PM
f150 Man
Exhaust Systems
Aug 12, 2006 03:29 PM
pipercub
Exhaust Systems
23
Mar 17, 2004 10:13 PM
acerockola77
Feb 29, 2004 03:28 AM
truckman79
Exhaust Systems
Jun 9, 2003 01:33 AM
