5.0 Poor Boy Performance
Old Nov 19, 2011 | 09:27 AM
Conanski's Avatar
Conanski
The system should build and hold 40-45psi within a couple cranks of the key(engine not started), and then maintain 32-35psi with engine running at idle and vacuum attached to the regulator. With the engine running if the throttle is blipped the pressure should rise momentarally(not fall). If your truck fails any one of these conditions you have a weak pump or possibly low voltage at the pump due to corroded connections or a bad ground, or possibly a clogged fuel filter or failing regulator. Also note there should not be any fuel in the vacuum line attached to the regulator.
RC Dan
Aug 19, 2015 05:53 PM
fuelie74
Feb 23, 2014 09:41 PM
TheTowingCowboy
Feb 25, 2010 10:17 PM
RockChalk99
Dec 6, 2009 09:09 PM
BEWOLD
16
Aug 19, 2007 07:12 PM
