Cobra Cam F3ZE
Consider the Gen. 1 Lightnings were rated at ~240 HP and 340 ft./lbs TQ with GT40 intake/heads/headers and a mild cam. The HO cam will net you a few more ponies up top but your stock 5.8L intake is going to hold your potential gains to a modest level. Yes the HO cam will work with SD, but to really get the full effect I would suggest a custom tune.
300 HP at the crank with a factory truck 5.8L EFI manifold? A Lightning couldn't do that with a GT40 intake, heads and a slightly hotter cam. Expecting that kind of increase with a truck intake, headers, Cobra cam and a stock tune is pretty optimistic even with a MAF conversion.
The Lightning guys have tried the HO cam and a few have done the Cobra cam swap. They have gained a few more HP, but it is at the expense of low end torque. From what I recall reading through hundreds of posts on their forums no one made 300 HP at the crank without using a much better cam and plenty of tuning with a Tweecer or some other programmer.
IMHO, 300 HP at the crank with a stock 5.8L EFI intake is not going to happen without some kind of forced induction.
Just my opinion, so take it for what it cost you...nothing.
on
Dyno Numbers After GT40 Head Swap!! - Corral Forums
Paul as usual you have a valid point. I wanted to back my viewpoint as well so I took two routes.
First didn't Ford make a hot-rodded Cobra R in 1995 using a 5.8L engine? Answer, yes. Here are several sources of the listed HP/TQ of this factory hot rodded 5.8L Mustang that used GT40 heads, R-spec'd intake and mass air:
Ford Mustang SVT Cobra - Wikipedia, the free encyclopedia
1995 Ford SVT Mustang Cobra R Pictures, Specifications, and Information
1995 SVT Cobra R Mustang Specifications
There are plenty more sources to back up the STATED horsepower for the 5.8L equipped Cobra R
Second point: I wanted to find some threads on NLOC that discuss and hopefully show us what a Gen 1 Lightning is capable of doing:
First thread starts out asking about the Cobra R. As the thread progresses there is some first hand track experience of using a Cobra spec.'d cam. No dyno info, but interesting reading for some of the specifications of the components and why they were used:
1995 Cobra R power? - The National Lightning Owners Club Inc
Here is an interesting thread where the OP dyno'd his truck using a HO cam. He states the truck dyno'd @231 RWHP with the stock GT 40 heads. The graph in the thread is with AFR165 heads:
AFR 165's with HO Cam Dyno Results - The National Lightning Owners Club Inc
What is the drivetrain loss to convert back to flywheel horsepower? Most threads use ~20% loss. So math would make the guesstimated FHP ~288HP. I am pretty sure the OP in that thread has headers, under drive pulleys and a custom tune. A little shy of 300HP, but actually close to Conanski's guess of ~300HP for the combo of HO cam, GT heads and stock intake. But I still think using the stock 5.8L EFI intake is going to kill most of the HP/TQ gain potential.
So again please take this for the price paid. Sorry to hijack the thread, but I want to put in my 2 cents worth to say I do not think the OP's intended combo will support 300 flywheel horsepower. What is the number? More than 215, but less than 300. Will the combo give more in the seat-of-the-pants feel compared to stock? Yes.
Keep us posted as your project progresses.
on
Some good real world numbers there, and yes my statement was a guesstimate of the potential as you know each particular combo will deliver different results. I don't think the stock truck intake is as bad as one might suspect, it certainly has a much better designed upper than the cars which have airflow restrictions just behind the throttlebody due to the mounting bolt locations. So I'm sure the lower is where it is restrictive just like with all other Ford intakes and some work on it would expand it's potential.
northdakota 67ford
12-16-2015 02:19 PM
5 Star Tuning
Vendor Specials, Discounts, Product Announcements & Group Buys
08-21-2015 11:50 AM
Show-N-Go LX
26
05-19-2004 08:37 PM
