5.0 Cam
Old Feb 22, 2010 | 05:47 PM
TheTowingCowboy's Avatar
TheTowingCowboy
5.0 Cam
I would like to put a cam in my 95 F150, something torque, for towing. My truck is still EFI, and I dont want to put a ton of money into upgrades but I want some powe upgrades, mainly a cam, maybe some bigger injectors, and a straight exhaust. But not much more. I am up for some others, but I am looking for a good cam. Something with alot of low range torque. Thanks guys. Take care.
Old Feb 22, 2010 | 06:22 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
A Comp XE256HR should be fine, although for lots of low end you'd do better with the stock roller cam and new heads...
Old Feb 22, 2010 | 07:43 PM
Conanski's Avatar
Conanski
There is no getting "lots" of low rpm TQ out of a 5.0.. not without forced induction, it simply isn't enough motor for a heavy truck. To maximize TQ output you will need a 5.0HO intake, longtube headers, and 1.7 rockers on the stock truck cam, but it still won't produce anything close to the grunt a 5.8 would for example.
Old Feb 24, 2010 | 01:36 AM
Hickfied's Avatar
Hickfied
No need to up the injectors until you are pushing 300+HP. I would suggest a HO cam and GT40 intake.
Old Feb 25, 2010 | 10:17 PM
Boba Fett's Avatar
Boba Fett
the best you will do is something around .480 lift.... because you are going to run EFI I would stick with motorsports and run a B cam.... and Conanski is right.... when youre talking 302.... your not talking torque...
