Compression test questions
Old Sep 20, 2011 | 06:04 PM
91Bronc300's Avatar
91Bronc300
I've done compression tests before but I've always just pulled one plug at a time then replaced them when moving on to the next cylinder. I'm wondering if warming up the engine, then pulling ALL the plugs, then replacing them one at a time after testing each cylinder will ruin the readings. I.E. so when testing the first cylinder the other 7 have no spark plugs in, and by the time I'm testing the last cylinder the other 7 all have their spark plugs in. This obviously creates huge vacuum leaks when those cylinder's intake valves are open, I'm just wondering if this matters. If it's necessary or not to have the other cylinders sealed up while testing compression.
Old Sep 20, 2011 | 06:42 PM
MiddleNameMUD's Avatar
MiddleNameMUD
Shouldn't matter ur testing that particular cylinder's compression...
Old Sep 20, 2011 | 07:40 PM
NW 150's Avatar
NW 150
the instructions for my compression tester say to warm up the engine to running temp, then turn it off, and remove all spark plugs, and go from cylinder to cylinder and check what they read.
Old Sep 20, 2011 | 08:25 PM
91Bronc300's Avatar
91Bronc300
So that means I've been doing it wrong up until now. Sounds about right
Thanks for the replies.
Old Sep 20, 2011 | 08:39 PM
NW 150's Avatar
NW 150
no prob that's what we're here for
Old Sep 21, 2011 | 08:08 PM
Tees77f150's Avatar
Tees77f150
Thats the way I have always done it, I check ALL cylinders and get readings, THEN put the plugs back in.
Old Sep 22, 2011 | 06:53 PM
donaldderby's Avatar
donaldderby
ase standard also removing all plugs
Old Sep 22, 2011 | 06:57 PM
91Bronc300's Avatar
91Bronc300
Thanks. That's the way I did it. Compression test came out good. 140 as a low and 160 as a high. Engine was cold and no oil was put in cylinders for a second test. I was happy enough with those numbers to not bother.
1954wrecker
20
Jun 27, 2018 09:16 PM
slimtim86
Aug 25, 2016 10:21 PM
Methodical_1
Feb 4, 2013 06:20 PM
rdweathers
Jan 3, 2013 07:48 PM
Boltgunner
17
Feb 6, 2006 10:58 PM
