Missing one cylinder
Old Aug 24, 2016 | 08:47 PM
slimtim86's Avatar
slimtim86
Hey guys. So here is my dilemma. I just finished rebuilding my 292 and fired it up for the first time. It fires up and seems like it is running great but when I check to make sure all of my cylinders are doing their part with my test light at the distributer cap I see that cylinder 7 does not bog the engine down like the rest.
I have pulled the valve covers back off to check the push rods and valve lash on every cylinder. Did a compression test on cylinder 7. Flip flopped spark plugs and wires with cylinder 8. I have good spark. I am at a loss right now. Any ideas? I'm hoping I'm just missing something simple.
Old Aug 25, 2016 | 08:06 PM
charliemccraney's Avatar
charliemccraney
What is the result of the compression test? Check at least a couple other cylinders to see how it compares.
Did the miss follow the plug wire, started missing on 8 instead of 7, or did it stay the same?
Old Aug 25, 2016 | 10:21 PM
slimtim86's Avatar
slimtim86
I got the problem figured out! The intake gaskets were a hair to small and cylinder 7 was sucking air instead of fuel. Put new gaskets on and problem solved.
jbarendrecht85
Aug 11, 2016 01:45 PM
obscurity
16
Aug 30, 2014 03:29 PM
cnoud22
1997 - 2003 F150
17
Jan 23, 2013 12:42 PM
91Bronc300
Sep 22, 2011 06:57 PM
Janimal
Jul 6, 2003 10:26 PM
