I am about to do my first compression test ever on an engine. I have a 390 and think there is a cylinder that isn't playing ball with the others . Any suggestions? I have taken out all the plugs, they all look good (alike) - plugs have a bit more than 15k on them (what is the change interval, please?).
Ok. Disconnect the coil. Keep the battery charged. When you find the offending cylinder, squirt a little oil down it to see if it's the rings or the valves. If the compression number comes up a lot, it's rings, otherwise, valves.
The spark plugs are probably due for replacement. I usually pull a couple at each oil change and take a look. If they're starting to round off, it's time for new ones.
OK - seven cylinders range from 145 to 170 psi (five compression strokes, carb wide open, good battery) but the cylinder at the forward end of the bank on the passenger side is only showing 68 (sixty eight) psi. I pulled off the valve cover and as best I could tell the springs look ok. About 15K miles ago these heads were purchased used, overhauled and bolted on to the block. All seems well except this corner cylinder. I did add oil to the spark plug hole and did not get a bump up in compression. Any more tests I can run?
My son's 360 (that I just finished completly rebuilding) also had low compression at the number two cylinder. Is this common? This was not a truck for the track. It was just a street/work vehicle. Perhaps this is just a random event, but it is an interesting coincidence.
Before we rebuilt the engine, compression was all over the map from 120 for 5-8 to 65 for cylinder #2. I noted that boltgunner also had low compression on cylinder #2 and was wondering if this was a typical pattern of just a random coincidence.
Random coincidence. FE's are no different than any other motor in this regard. They should be as close to each other as possible. A low reading indicates a problem.
My Ford factory shop manual stated that having a low pressure that was higher than 75% of the highest pressure was good to go. That was for any truck engine in '76. My highest was 170, so according to the chart in the book I was OK at 127 or higher. Still, I got a bleeder with the front RH corner banger.
boltgunner has a low reading on cylinder #1, not #2. FE (and most other Ford V8) cylinder numbering is #1 thru #4 from front to rear on passenger side and #5 thru #8 front to rear on drivers side of engine. FWIW
OK, I have slept since I did the compression check, so now I am wondering what it would take to drop that pressure to 68 psi. Anyone have some ideas why this amount of drop in pressure? This head has not been on the truck long. She runs sweet above idle, smooths out a bit at the stop light when I drop her in neutral. Just annoying little vibration that tells me that I have some knuckle-bustin' ahead. Arrgh.
I would also expect a valve issue, a hung open valve(caught in guide) or a burnt exhaust are the most likely. I once had a valve hang up on a 289 with all new valvetrain with only 1000 miles on the motor. Never did figure out why it seized(exhaust valve).
