Slight vibration on the highway
Hey guys im new to the forums and hoping you guys can give me some insight. I have an 03 expedition that i just rolled 132k miles on the other day. When driving around the city she drives great but the highway is a different story. When driving around 70 to 80 it seems to pick up a vibration that seems almost harmonic in nature. Its not very intense but definitely noticeable when paying attention to it. I've replaced just about every front end component including the steering rack, inner and outer tie rods, idler arms, upper and lower ball joints/control arm on the uppers. Would love to get her to drive like new, so any ideas?? maybe bearing or cv joints?? I also had the tires balanced at discount tire co and that didn't help the problem
Set the e-brake, chock the wheels, shift into neutral (engine off.) Then go under the truck and try to pry the two halves of each joint in several different directions to see if there is any play. There should not be any play.
The front end parts were all done about 5k miles ago as to a shimmy in the steering wheel. Replacing those took care of the steering wheel shimmy however the vibration on the highway has only been around for about the past 2k miles and that can be felt in the seat. I checked the bearings last time i had the car up on stands by grabbing the sides of the tire and checking for play.They seemed to be fine but im not sure how accurate of a test that is to check them.
makemeknowit
1999 to 2016 Super Duty
15
09-24-2018 01:18 PM
