Odd Vibration
Old Aug 7, 2014 | 10:58 AM
mrmurph's Avatar
mrmurph
Odd Vibration
OK guys, here are the specifics.
2003 Limited, V10, 4x4, 178K miles. Running factory sized tires.
Within the last month or so, the truck started exhibiting a vibration at certain speeds. This vibration is felt at right around 2,000 RPMs (55-60 mph in 3rd, 70 mph in OD) and is only present when the vehicle is under load. By that, I mean if we are coasting, there is not vibration. I have been under the truck and suspect that the rear drive shaft U joints are the cause, specifically the rear u joint. I can't move the drive shaft but one of the dust covers (seals) is obviously pulled away from the cap. My theory is that this is likely the root cause of this vibration.
Your thoughts? No matter what, I am replacing the U joints tomorrow. I'm just curious if you all agree that this is the cause.
Many thanks!
Old Aug 8, 2014 | 01:57 PM
mrmurph's Avatar
mrmurph
U joint replaced, vibration gone.
Next week, new ball joints.
Old Aug 8, 2014 | 02:04 PM
Apocalypse's Avatar
Apocalypse
Glad to hear I was watching the thread but didn't really have anything to add and was hoping it was the U joint. Good luck in the ball joints!
noimports
Apr 22, 2018 09:08 AM
baarroyo98
2009 - 2014 F150
Jan 6, 2018 11:05 PM
superduty4x4
Apr 21, 2008 08:46 AM
Talyn
May 26, 2004 08:32 PM
