need help with some codes, SES light on
Old Aug 18, 2009 | 06:03 AM
shark1979's Avatar
shark1979
after fixing my oil leak and installing FRx and AHI delete i now have a SES light on with codes P2010,P2011,P0238. i know about the 2011, not sure about the other ones, so any help would be great.
Old Aug 18, 2009 | 06:08 AM
shark1979's Avatar
shark1979
and now i get a P0541 code along with the 2010 and 2011,
Old Aug 18, 2009 | 07:06 AM
megawatt00's Avatar
megawatt00
P0541 Manf Intake Air Heater Circuit Low
This is due to the AIH being deleted it is a soft code. Clay does have the code eliminators for it.
P0238 Turbo Boost Sensor A Circuit High Input
Do you have a boost fooler installed? This is probably from the map seeing an overboost
Old Aug 18, 2009 | 07:29 AM
shark1979's Avatar
shark1979
This is Shark's girl he's at work without access to a comp. Lucky for him at my job I can access a comp. So I"m going to post for him so he can hopefully get this fixed!! He doesn't have a boost fooler. He cleared the codes so is it safe for him to drive or no? Any ides on how to fix it?
Old Aug 18, 2009 | 07:35 AM
megawatt00's Avatar
megawatt00
It is fine for him to drive it. The codes will come back though. The boost fooler will limit the amount of psi that the MAP sensor sees. Anything over iirc 22+ psi on the MAP sensor will cause the SES light to trip. It is common to get this code when running tunes without a fooler.
Old Aug 18, 2009 | 07:45 AM
shark1979's Avatar
shark1979
Thanks for the help as always!!!
Old Aug 18, 2009 | 07:48 AM
megawatt00's Avatar
megawatt00
Your more than welcome. Have a good day.
Old Aug 18, 2009 | 11:16 AM
shark1979's Avatar
shark1979
so this is josh thanks for the help, just cleared the codes again, started the truck and get 2011,2010 0340 with out leaving my drive way most of the time i have to drive it hard to see the 2011. what is the 0340
Old Aug 18, 2009 | 11:18 AM
shark1979's Avatar
shark1979
and just got a 1280 this time also i am using a scan gauge to get these codes if that makes a difference
Old Aug 18, 2009 | 11:50 AM
megawatt00's Avatar
megawatt00
P0340 Camshaft Position Sensor Circuit Error
P1280 ICP Circuit Out of Range Low
Check your ICP connector for oil
What are you running for a CPS Josh?
Old Aug 18, 2009 | 12:41 PM
shark1979's Avatar
shark1979
Josh's girl again he's running gray but he has an extra one how does he change it??
Old Aug 18, 2009 | 04:12 PM
shark1979's Avatar
shark1979
thanks for your help JIm truck seems to be running fine now, do you think i should change my CPS?
quote=megawatt00;7841949]P0340 Camshaft Position Sensor Circuit Error
What are you running for a CPS Josh?[/quote]
r___r
Sep 10, 2014 12:31 AM
Tormz
15
Nov 26, 2012 07:18 PM
shark1979
20
Aug 1, 2010 08:18 PM
IM1096
Nov 6, 2007 04:55 PM
nimrod6979
Jul 21, 2004 02:34 PM
