Warm up time
Old Sep 20, 2011 | 08:59 PM
  #46
clux's Avatar
clux
Originally Posted by BigAlsPSD
Whether or not it helps or not, I always wait til my GPR Led goes off, this summer 100+ temps, GP's would be on first thing in the morning after sitting all night for 30 seconds to a minute still, I just don't like the idea of a "Lit" hot plug sticking in the cylinder with the engine running personally, seems like if they were hot enough with the compression in the cylinder they could distort, not likely but thats my logic as well as the added amp draw.
The glow plugs continue to heat for up to two minutes after the WTS light goes out.
Old Sep 20, 2011 | 09:02 PM
  #47
BigAlsPSD's Avatar
BigAlsPSD
I know that, I just didn't think they should be heating while it was running in my logic. So I've always waited for them to turn completely off.
Old Sep 20, 2011 | 09:14 PM
  #48
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Then you should disconnect them. They stay on after the light goes off for some period of time, dependent on temperature.
Old Sep 20, 2011 | 09:18 PM
  #49
BigAlsPSD's Avatar
BigAlsPSD
That's why I have a LED wired to them so I know when the GPR disengages, I must have worded something wrong, I understand that they stay on longer or do not even come on due to various parameters. I was stating that even in the summer with high temps, I waited until the GP's were off before I started, which even at 100+ degrees was quite a while. I like the idea of just warming the cylinder, rather than using the glow plug as an ignition aid is I guess the wording I should be using.
Old Sep 20, 2011 | 10:01 PM
  #50
BigAlsPSD's Avatar
BigAlsPSD
Maybe I just realized I have been starting my truck, as well as all other diesel's I've driven entirely wrong, as i guess you do need them for ignition aid. I've never had Romps, running synthetic too though, no smoke on startup either, but I didn't realize I needed the glowplugs as ignition aid when cold. I apologize, and will try to use them correctly.
Old Sep 21, 2011 | 12:59 AM
  #51
slim613's Avatar
slim613
Originally Posted by Franko72
Back in 2006 I got a brand new Kenworth with a C13 Cat, when I took it to Cat to get neutered I asked the mechanic about recommended warm up times. "He said just long enough to build air pressure, and you shouldn't have any leaks, so you should have pressure as soon as it starts"
since then I turn the key and drive away. It warms up much faster going down the road anyway.
that the cat 3406 i cant rember wat C it is?
Old Sep 21, 2011 | 05:31 AM
  #52
Franko72's Avatar
Franko72
Molon Labe
The 3406E was an older model number, (1994-1996), its a 14.6 liter. The 3406E from 97-99 was a 15.8 liter. They now call the 14.6 & 15.2 liters a C15.
Old Sep 21, 2011 | 09:47 AM
  #53
slim613's Avatar
slim613
there we go, im tearing one down right now, and my dad had one in his 359 peterbilt and it was a runnin suck beech, i like the mechenical one tho
Old Sep 21, 2011 | 04:28 PM
  #54
Franko72's Avatar
Franko72
Molon Labe
Both 3406's are great motors. I personally like the Detriot 60 series, spent alot of time behind many with very little troubles. Cats do have good sound, especially when cold.
Old Sep 21, 2011 | 04:34 PM
  #55
RainStroked's Avatar
RainStroked
I have yet to hear a diesel motor that doesn't sound good and mean when cold.
Old Sep 21, 2011 | 05:14 PM
  #56
slim613's Avatar
slim613
not the D word i hate the 60 series the oil spittin thing, we never had problems with are 3406 and it would scream 135 mph down the hwy
jfralph
6.7L Power Stroke Diesel
Feb 11, 2014 01:54 PM
ttttmaxx
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jan 15, 2011 10:26 AM
bcaughhorn
Dec 1, 2010 10:14 AM
jtharvey
Jan 24, 2007 09:37 AM
Quadzilla
34
Apr 3, 2002 12:48 AM
