LONG CRANK TIME MOSTLY WARM
Old Sep 19, 2011 | 10:17 PM
Sonny Dee's Avatar
Sonny Dee
Having problem locating issues on starting with long crank time. Glow plugs buzz out ok, relay working fine. Actually cold start in morning starts pretty normal, once it gets warm is when it takes longer cranking time to start. Batteries are new, I replaced starter about 3 years ago with the 2 bolt high speed, it seems to be cranking ok. If I park on a hill, pop the clutch in 2nd, it's fired up immediately, don't think it turns over twice, just can't get it cranking. I was advised that it may be low pressure on the HPOP, just don't make sense with the quick 2nd gear jumpstart. Truck is a early 99 dually 6 speed, mileage....91K. Any advice would be helpful..thanks.
Old Sep 20, 2011 | 01:13 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Check your EBPS and tube. Also, I have to ask. Do you have good oil in the truck?
Old Sep 20, 2011 | 02:05 AM
RainStroked's Avatar
RainStroked
Sounds like it could be the injector o-rings, but 91k seems kind of early. Mine were starting to get a little bad around 200k, I too had long warm cranks with faster cold cranks.
Old Sep 20, 2011 | 06:43 AM
Sonny Dee's Avatar
Sonny Dee
What's the EBPS and tube, not sure on that one, using Rotella 15-40...about 800 miles on it....I changed oil early hoping that might contribute to the prob...didn't change.
Old Sep 20, 2011 | 06:46 AM
Sonny Dee's Avatar
Sonny Dee
At 79K cracked fuel rail in a head down in SC...man, did they "fry my chicken"...anyway.. all new under the valve covers..seals oil rings etc....
Old Sep 20, 2011 | 10:06 AM
ggirten's Avatar
ggirten
Mine was doing the same thing. After a couple of months of research, I finally put a new HPOP in last week. It runs great and starts great. Just took a while for me to spend the money on a new pump not being sure that was the problem. I put a scanner and watched the injector pressure. It would start cold and be about 3200 but as it warmed, it would slowly start dropping until it was in the 400 range and die. The new pump holds over 3200 all the time.
Old Sep 20, 2011 | 05:28 PM
Sonny Dee's Avatar
Sonny Dee
Thanks for the info...seems to be going that way. How many miles on your smoker? It's hard for me to understand all these failures at 91K, see guys up in the 200's just starting to have problems....new waterpump, starter,oil cooler seals, now looking at HPOP, replaced hub bearings, upper an lower B joints, tie rod end and I take care of mine faithfully...pisses me off, maybe just a product of early 99.
Old Sep 20, 2011 | 05:39 PM
BigAlsPSD's Avatar
BigAlsPSD
Before you go throwing a new HPOP you should try to get it properly diagnosed, Usually longer starts with warm oil deals with IPR issues, lots of other possibilities before I would personally replace a HPOP. LPOP issues, weak batteries, other various things. There was a post here about "it's never the HPOP" thats what I usually abide by when trying to diagnose HPOP issues.
Old Sep 20, 2011 | 07:14 PM
ggirten's Avatar
ggirten
I agree. I first put in a LPOP because I had a new high volume low pressure given to me. I also had extra IPR and ICP, so that rules those out. My batteries were both new. I had a scanner to watch the Injection pressure and duty cycle and both were out of the norm. I was still reluctant to put in a HPOP, but that was ultimately my issue.
Mine as 285,000.
Old Sep 20, 2011 | 09:48 PM
Sonny Dee's Avatar
Sonny Dee
Mine as 285,000.
All good suggestions, all good reasons....I have a question that a good answer might help me go in the right direction.....What's the relation to the HPOP between crank starting and jump starting? Warm start...crank about 7-8 seconds +-....anytime everytime, no romping, no smoke then bam, she's lit up. On jump starting...I said 3rd gear it's 4th gear, rarely use low..probably role 15 ft, pop clutch and it's lit..maybe turns over 2 or 3 times. So, if a weak HPOP, wouldn't it take just as long jump starting as cranking? Why is it longer on crank than jump, where does a weak HPOP fit in on this analogy. I just did a amp test on both bats on a warm start, starter drawing a steady 45 amps on each battery until it starts. Do you know what a normal draw should be? Thanks again.
Old Sep 20, 2011 | 10:30 PM
bulla's Avatar
bulla
Just curious but what do you mean by cracked fuel rail?
Old Sep 21, 2011 | 07:30 AM
ggirten's Avatar
ggirten
When mine would quit, it would not start on its own. But, (I know the dangers) if I used a little starting fluid it would fire up. My guess is the motor is turning a little faster therefore causing the pump to turn faster and building pressure quicker.
Old Sep 21, 2011 | 07:34 AM
Sonny Dee's Avatar
Sonny Dee
Refering to the chamber inside the head that carries the fuel from the extenal line outside to the injectors. In "gas" it's a external fuel rail...I guess with diesel it's internal fuel rail. That casted chamber cracked and the high pressure fuel was going into the coolant system...happened in South Carolina on the way back from Fl.. stealership nightmare and truck will never be the same.
Old Sep 21, 2011 | 08:39 AM
bulla's Avatar
bulla
Yea I doubt it was the casting. Probably was just an injector cup and didn't know any better or saw you coming! Lol. Guess it's over now but hang around, we'll get it figured out!
Old Sep 21, 2011 | 08:46 AM
bulla's Avatar
bulla
I think the starter probably only spins the motor at 100 rpm's or so. When you dump the clutch your motor is instantly turning 500-1500 rpm's! Big difference! I would have the icp monitored while cranking! Where are you? Maybe someone close by has an ae can help you out! The brotherhood is good about that!!
