Coolant leak from back of engine, only when cold
09-16-2011, 10:19 AM
on
Have seen an intermittant coolant leak from back of engine only in the mornings when the temperature is "cold" (I live in central Texas so cold right now is in the upper 60-low 70's) Once things warm up, outside temp or engine temp, leak stops. Any ideas?
Reason: title was wrong
09-16-2011, 11:22 AM
on
Just a question to maybe help others answer you better:
which side of the motor is the leak coming from?
Dave
09-16-2011, 11:28 AM
on
Mainly the passenger side but once a little from driverside too.
09-16-2011, 11:52 AM
Oil cooler outlet hose maybe. Can see it passenger side under intake manifold top of engine. Orange is older hose, blue is newer style.
09-16-2011, 12:39 PM
on
Thanks Rusty. Is there a reason it only leaks when cold? If this is it, how difficult to change out?
09-16-2011, 07:54 PM
09-17-2011, 04:41 AM
My 03 had the same thing - but I traded it on the 05 before getting it fixed as it was so intermittent...
09-17-2011, 08:16 AM
on
Mine truck had the same issue 4 yrs ago. still under warranty. Turned out to be a O'ring that would swell up when hot drawl up when cold and leak.
lawnspecialties
1999 to 2016 Super Duty
01-18-2020 02:57 PM
2006fordf25060
01-12-2018 10:49 AM
peefrog
6.4L Power Stroke Diesel
18
05-31-2011 07:23 PM
joe blow
03-06-2007 11:25 AM
Crewchief88
01-06-2007 11:39 AM
2003 ,
2006 ,
360 ,
59 ,
cold ,
coolant ,
diesel ,
engine ,
f250 ,
leak ,
leaking ,
motor ,
passenger ,
rear ,
side
