2002 Explorer A/C Clutch
Old Sep 16, 2011 | 06:39 AM
charbaugh's Avatar
charbaugh
I need to replace the A/C clutch on my 02 with a 4.6L V8. Does anyone know if this can be done without removing the whole compressor? I am trying desperately not to have to evacuate and recharge the system. This isn't covered in the repair manual I have, but I assume I am going to need a puller to get the pulley off. My concern is the lack of room between the compressor and the radiator.
I have alreaday tested all of the pressure switches and made sure there is power at the clutch itself. Initially, I could tap the clutch with the handle of a screwdriver and it would work for a few days, so I thought maybe it was just the gap. Now that doesn't even seem to work. A new clutch at the local parts store is only $100, so I figured I would go ahead and replace it. If anyone has any tips on this, I would love to hear them. Thanks!
Old Sep 16, 2011 | 07:20 AM
projectSHO89's Avatar
projectSHO89
If the clutch pulley bearings are still good and your only problem is lack of clutch hub engagement due to excessive gap, just buy and install a new Motorcraft clutch hub. Set the clutch gap with the appropriate thickness shim when reassembling.
charbaugh
Sep 16, 2011 04:30 PM
kidoo
Aug 20, 2006 04:14 PM
tbirddmnd
Jun 16, 2004 10:02 AM
bradleyj
Jul 18, 2003 02:30 PM
