Is there a way to make the air that blows out of the a/c vents smell fresh. Sometimes on my 02 F250 7.3 4x4 it smells musty. How can I correct this.
Thanks
That smell is usually caused by mold in the evaporator housing. Dirt and debris gets trapped in there and holds moisture, leading to mold.
The only 100% way to get rid of it is to remove the evaporator housing and clean it out. Not a small job.
Try running the blower for a few minutes with the AC off before you shut it down. This can help dry up the inside of the evap housing. Liberally spraying Lysol in the air intake with the blower running will kill the mold for a while, but it will come back.
