Need Help Fast
Old Sep 15, 2011 | 10:54 PM
4CFarms's Avatar
4CFarms
Need Help Fast
Ive noticed that when i start the truck up, and put it into drive an push the throttle that it seems like the brakes are locking up. It has a harsh squeel forthe first 10 feet, but then it is fine... im scared to drive it much so i dont do further damage so please help me figure out whats wrong! it sounds like its coming out of the front axle, but it might be from the rear
thanks, Luke
Old Sep 15, 2011 | 11:22 PM
pjwoolw's Avatar
pjwoolw
Could be a caliper sticking. What does the pedal feel like?
Old Sep 16, 2011 | 06:38 AM
DIYMechanic's Avatar
DIYMechanic
Yeah it sounds like you need to jack the thing up and try to spin the wheels by hand. Note: you will likely want to try to jack up the whole rear axle and spin both wheels simultaneously if you have a limited slip differential in the back. It sounds to me like you have a caliper or drum that is hanging up.
Old Sep 16, 2011 | 06:49 AM
Talyn's Avatar
Talyn
drums love to hang.
At least you can adjust those without taking the tires and drums off.
Old Sep 16, 2011 | 06:53 AM
DRRXR's Avatar
DRRXR
Could be caliper, rubber hose to caliper (internal cracked rubber) can act like a flap and not allow the fuild to release.
Could be bearing too. Or master cylinder distribution.
As soon as it makes the noise next time put it in park and then reverse your direction of travel and post if it made a difference and then---
Do as DIYMechanic said as soon as it binds with the noise. Jack it up and spin them. Also have you had to add break fluid? If so you can have a hyper extended shoe set.
Dont know what kind of wheels you have on the front but you should be able to see thickness on the front pads just by looking.
Morning Guys;0) you too Wild Bill
Old Sep 16, 2011 | 07:13 AM
4CFarms's Avatar
4CFarms
the squeel only happens when i pull out going foreward, it doesnt happen when i go back wards. so would it deffinately be the rear brakes then?
Talyn's Avatar
Talyn
How did you know my nickname was Wild Bill? (it really is.)
Old Sep 16, 2011 | 07:26 AM
DRRXR's Avatar
DRRXR
Remembered from away back post- you know when you got the spanking for too much cornification lol
Anyhow back on task-
Chock the front tires jack up the rear and hand spin them forward.
If there is a bind (pull the tire) then loosen the shoe spreader bolt (rear side of drum just under the axle at the slit in the plate. You may have to use a screw driver to spin it to loosen it. Then ping the hub at 12 3 6 and 9 and pull it off and see if the shoes are worn off or hyper extended. Look for oil there too. Sorry if thats too much info on the removal- just dont know what you already know
Last edited by DRRXR; Sep 16, 2011 at 07:37 AM. Reason: forgot to pull the tire lol
Old Sep 16, 2011 | 07:57 AM
Talyn's Avatar
Talyn
I am the red bean king. haha.
Old Sep 16, 2011 | 05:58 PM
4CFarms's Avatar
4CFarms
alrighty, thanks ill give it a try
Bendit
Mar 30, 2018 11:41 AM
awcforever
1997 - 2003 F150
Jul 6, 2012 07:42 PM
fordman1264
2009 - 2014 F150
Nov 23, 2010 09:44 PM
fullauto 74 f100 390
Mar 22, 2008 07:23 PM
stargehzer
Oct 27, 2004 08:50 PM
