Rear end Questions
Old Mar 22, 2008 | 06:50 PM
fullauto 74 f100 390's Avatar
Question Rear end Questions
why is it that both my rear wheels drive when i get stuck in mud but when i try on pavement or just a bit of a peel out on gravel you know what i mean anyway does only one wheel drive then even though im spinning there to ??????? signed dazed and confused
Old Mar 22, 2008 | 06:58 PM
85e150's Avatar
85e150
Either you have an open diff which spins both tires sometimes when conditions are right or a weak limited slip which has enough strength to hold under low traction conditions like mud but won't hold when traction increases. Limited slips have clutch/spring packs which are subject to wear and weakening.
Check for a tag on your axle, on one of the studs holding the carrier into the housing, at about 5 o'clock some folks say.
The numbers/letters on it will tell. Post and get a reading.
Old Mar 22, 2008 | 07:02 PM
yah im thinking its worn out a bit its a 1974 truck as for the tag i need to like soak it in clr for like an hour to remove the rust on it so it could be a while lol
Old Mar 22, 2008 | 07:23 PM
jokerforever's Avatar
jokerforever
Chock the front wheels and jack the truck up by the rear axle so that both tires are off the ground. Then, with the trans in neutral, turn one of the rear wheels by hand. If the other one turns the opposite direction you have an open diff. If it turns the same way you have some kind of traction device.
RiceBiker
Sep 29, 2014 10:06 PM
FordRun
Nov 27, 2012 04:49 PM
hi-jacker
Jan 27, 2007 09:54 PM
deere81
33
Jul 12, 2001 12:42 AM
Sean_2
1997 - 2003 F150
Jun 27, 1999 08:25 AM
