Broke down axel issues
Old Mar 25, 2018 | 03:38 PM
Bendit's Avatar
Bendit
I have a 1989 f350 that the drivers side wheels locked up and the axel won't come out tried 2' slide even and still won't budge . Any help would be great thanks in advance!!!
Old Mar 29, 2018 | 11:58 PM
1TonBasecamp's Avatar
1TonBasecamp
Wheels, plural? Both front and rear? Or is this a dually?
If a rear axle, could it just be glued in place by a previous batch of silicone sealer?
It would be nice if it's that simple, but I'm just throwing something out there to get you back to the top. On the surface it sounds like two separate issues, but if an axle broke and jammed up inside, that could cause both.
Do you know if your differential is a limited-slip?
Good luck.
Paul
Old Mar 30, 2018 | 09:07 AM
Bendit's Avatar
Bendit
Broke down and busted
yes Paul limited slip and it's the rear end sterling 10.25 up on stands the passenger side will turn while in gear the driver side is locked . I heated where the axel bolts in with heat gun and used a two foot slide hammer and it won't budge
Old Mar 30, 2018 | 10:07 AM
mrollings53's Avatar
mrollings53
How are you attaching the slide hammer to the axle shaft?
Old Mar 30, 2018 | 11:31 AM
Bendit's Avatar
Bendit
Around where it attaches to the housing with the 8 bolts
Old Mar 30, 2018 | 11:32 AM
Bendit's Avatar
Bendit
Thanks everyone for your help and input!!!
Old Mar 30, 2018 | 11:41 AM
mrollings53
Are you using the bolt holes, or gripping the flange somehow?
AZFordLover
Jun 7, 2019 10:05 AM
ragboat
15
Dec 18, 2018 11:43 PM
RangerDanger667
Jul 4, 2018 02:14 AM
BSF350
Nov 29, 2017 03:54 PM
mustangz_04
Aug 12, 2004 02:30 AM
