Snow Plow advice
Old Sep 13, 2011 | 08:55 PM
jimzigg's Avatar
jimzigg
Snow Plow advice
Looking into adding a 8.5 ft plow approx 800 lbs. Plowsite.com has a number of Ex plow runners but I have not had any success to my posts.
Question is about springs in front. I know that most suggest upgrading springs to X or V code to run the plow. My installers said to forget about new springs or "add a leaf", he uses Air Lift product called Air Cells with good success. There is no direct application for the Ex but there is one for the F250 and also the F350 both w/o snow plow prep pkg. I assume both those trucks had stiffer springs to begin with than the Ex but wondering if the Air Cells might be enough to hold the plow? I also would assume the F250 spring was softer than the F350 and would be closest to the Ex spring.
Any experience here? Will I still need to put blocks in rear?
Old Sep 13, 2011 | 09:12 PM
wpnaes's Avatar
wpnaes
Never heard of Air Cells. The Ex isn't the most common plower - find a used plow and bolt /wire it up. Just change out to the X codes's and plow away. The plow will 'hold' with your stock springs, it'll just be a rough ride on what's left of your front bumpstops when the blade is up. See how it looks with the X codes and plow before messing with the rear. Honestly, consider a shorter wheelbase truck already set up for plowing before sinkin' money into the Ex Plow. I bet you could find a 15yr old, very rusty truck/plow already set up for what it'll cost to convert your Ex with a new Meyer/Western. My 2c.
Old Sep 13, 2011 | 09:26 PM
jimzigg's Avatar
jimzigg
Thanks. I have considered a dedicated plow truck but can get a used sno-way set up installed for $1800. The air cells actually sit in place of the factory bumpstop:
Air Lift Air Cell Helper Spring Kit, Air Lift AirCell - TruckSpring.com
Old Sep 14, 2011 | 08:50 AM
airjeff's Avatar
airjeff
I'm not sure those would work because there is so little space between the frame/bumpstop and spring. The X codes would give you enough room, and the V codes might, but I'm not sure. If that shop has done it have them take a look and they'll know how much room they need.
Old Sep 14, 2011 | 11:09 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
go X code and forget about it. they will hold it wonderfully.
i'm debating on adding a plow mount/wiring for my boss plow to my excursion, so i would have a option of running either my f250 or excursion..we'll see.
Old Sep 14, 2011 | 11:57 AM
jimzigg's Avatar
jimzigg
thanks for feedback! i confirmed that aircell has no application for the excurison and using the f250 version may not be possible due to spring difference. however, i did find out that timbren does have an excursion application about $200 for the same sort of load support "bump stops" and are rated at 3000 lbs. i assume there will be enough room to place the timbrens in due to the availability of the product. if i get a confirm i will post it here.
Old Sep 14, 2011 | 08:14 PM
housedad's Avatar
housedad
I had looked at getting a plow early on. Studied it pretty hard, too.
At the time, I had decided that this would be the correct solution for me:
Front Airlift springs (air bags) for Ford Excursion
Air Lift Company LOADLIFTER 5000; LEAF SPRING LEVELING KIT - 4 Wheel Drive
And use this with V code springs, (best ride when running without the snowplow) However, the air springs are enough by themselves to handle the plow.
also could use W code for weight control along with the front bags, but they will give a 2.5 inch lift in the front all by themselves, *** opposed to 1.5 to 1.75 inch lift of the V codes
The above solution beats the hell out of Timkens or other passive systems. You have the capability of having the suspension beefed up, or riding smooth depending on whether hooked or not, and maintain a decent suspension travel distance while travelling from place to place with the plow. With the Others, they are basically a snubber that allows your frame to ride on the axle. Not too fun if you hit a bump.
Old Sep 14, 2011 | 08:28 PM
housedad's Avatar
housedad
One more thing.
If you get the airbag systems, paint the galvanized hardware real good after it is installed to reduce corrosion from salt.
JoelPM
Sep 11, 2017 06:32 PM
wannaBelkhuntin
Nov 17, 2012 09:24 PM
immastrokinnow
Nov 10, 2008 02:22 PM
immastrokinnow
Oct 20, 2008 08:51 AM
Wilson & Co
Sep 9, 2008 09:14 AM
