Swapping EFI components into '86
Old Sep 12, 2011 | 07:25 PM
Blue86's Avatar
Blue86
Like the title says, I have a carburated 86 F-150 with a 4.9L. I have another 4.9L from 1992 with all the EFI components and harness still attached. Has the swap been done before? Is it as easy as powering up the EFI computer and attaching a harness? I can't imagine it's that easy or I'd have heard about it. Anyone have some advice on this one?
Old Nov 27, 2011 | 07:34 PM
Blue86's Avatar
Blue86
The answer to this one is that it's that easy. Hook it up and let it rip. Thanks for all the help on this one folks.
Old Nov 28, 2011 | 06:27 PM
kedwinh's Avatar
kedwinh
Didn't know the answer but have thought about it myself. Thanks for the heads up.
Old Dec 1, 2011 | 01:09 PM
Andrew7dg's Avatar
Andrew7dg
I was wondering about this also, except mine is a v8 engine
however I was wondering about fuel tanks and fuel pumps
Where is the electric fuel pump located on the EFI models?
I have two tanks and was wondering also how does the switch over (or where it occur) and would this still function if I went to EFI?
Old Dec 1, 2011 | 04:06 PM
AbandonedBronco's Avatar
AbandonedBronco
On the EFI models, the fuel pumps are located in the tank.
As for the tank, it depends on the year. I know on Broncos, the 80 - 89 tanks had a 2" sending hole, and the 90 - 96 tanks had a 3 5/8"
Old Dec 1, 2011 | 08:00 PM
kedwinh's Avatar
kedwinh
I wondered about that to, weather you could just use a external high volume pump instead of swapping tanks. I know aftermarket EFI's use them.
F125Lariat
Jun 13, 2019 05:30 PM
TIE-APX1
Jul 24, 2015 03:09 PM
Systems2000
Dec 25, 2008 01:03 PM
ford390gashog
Aug 31, 2004 09:34 PM
slick78
Jan 21, 2002 12:05 PM
