Carb to EFI?
Old Dec 24, 2008 | 04:29 PM
Systems2000's Avatar
Systems2000
Carb to EFI?
What's involved in using an EFI engine in a non-EFI vehicle?
Would it be less trouble to just replace the intake/fuel system (ie. EFI to Carb (NA)).
Old Dec 24, 2008 | 07:59 PM
court1100f's Avatar
court1100f
Well if your talking about getting the EFI engine out of another vehicle to do the change over you'll need everything that came with the EFI engine Wiring harness,computer,sensors the works....But if you mean to convert an engine already in there to EFI Edelbrock and Holley sell aftermarket systems that come with all you need in Multi port and Throttle body injection. However if you want Factory equipment I believe you would have to change the heads and intake and add the EFI stuff and take a trip to the junk yard to aquire the Wiring harness ECM and sensors and stuff
Old Dec 25, 2008 | 09:34 AM
Systems2000
I'm referring to removing a 300-6 NA ('87) and replacing it with a 302-8 EFI (supposedly from an '85). This seems out of sequence to me. Did Ford take longer to convert trucks to EFI?
I'm not looking to replace the manual transmission. The '85 was mated with an automatic.
Old Dec 25, 2008 | 01:03 PM
court1100f's Avatar
court1100f
hmm I think the 85 302cid ran CFI Fords version of TBI, in 86 you could get a multi port fuel injected 302 as an option in 87 Multi Port Fuel Injection became standard equipment on the 300s and 302s the 351W and 460 Followed up in 88. GM took the longest to go to Multi port EFI on their trucks they continued running TBI into the 90s not sure how long they continued using it
Filthy_F100
Jan 17, 2017 04:38 PM
abrojal
Jan 21, 2014 12:47 PM
wantaford
Nov 5, 2004 10:39 PM
lostinatl
May 6, 2002 06:48 PM
winfordr
Dec 16, 2001 07:50 PM
