Engine losing power...possible problems?
Old Sep 8, 2011 | 01:14 AM
henslee's Avatar
henslee
ok, so i got this truck running i bought, its an 84 f250 (diesel). now, problem is when i start it, depending on whether its happy or not it will run different. some times engine will roar to life, and sound powerful when i hit the gas, and sometimes it will barely get past idle. even when it is running good (presumably) i will take it for a quick drive, just a few miles, and the engine will eventually start slowing down and losing power, acting almost like its losing gas.
best way to explain it, it acts like im letting off my gas pedal when i am not
im thinking that its a problem with the fuel injector pump being clogged. main problem is am mechanically handicapped for this is my first ever vehicle. any suggestions, solutions, comments, or even negative feedback?
Old Sep 8, 2011 | 08:33 PM
Franklin2's Avatar
Franklin2
Get a new fuel filter, and a bottle of diesel clean or some other diesel fuel cleaner/additive. Take the additive and pour it into the new filter to fill the filter up, and then carefully screw it onto the engine, start it, and see if that makes a difference.
P.S. Warm the engine up before doing the above so it starts easier after you change the filter.
Old Sep 9, 2011 | 12:08 AM
henslee's Avatar
henslee
ok, ill have to try that.... dont have many other options.
What im afraid of though, is that the fuel injection pump my be going bad, or is just dirty inside. because when i start it it tends to let out alot of white-ish smoke, and today it smoked for a good 5 minutes straight. this along with engine power loss is most common symptoms of a problematic FIP.
Anyone have any tips for cleaning, or just replacing the filter on the pump? i cant find any diagrams, even in my service manual, on where the filter is inside the pump.
Old Sep 10, 2011 | 09:08 AM
Holmesuser01's Avatar
Holmesuser01
Worry if it still acts up AFTER you replace the filter.
Other than the glow plug relays acting funky, I've heard little about these engines.
Old Sep 10, 2011 | 09:55 AM
Franklin2's Avatar
Franklin2
If there is a filter in there, it should not have a problem, the large screw on filter catches most of the dirt. The 100% concentration of diesel cleaner in the new filter usually breaks most stuff loose.
White stinky smoke out of the exhaust is just unburnt fuel. Do you have a automatic glowplug controller still on it or do you have a manual button setup? If some of the glowplugs are not working, it may still start, but it will miss and smoke till the cylinders with the faulty glowplugs build enough heat to start burning the diesel fuel. This engine has no sparkplugs, it works on heat only.
A couple of bad or clogged injectors can also cause smoking. If they are not not misting the fuel into the cylinder, the fuel will tend not to burn correctly. The concentrate of fuel cleaner may help this also.
The most common failure mode of the pump is the engine will not start after it gets hot. The timing being off can also cause crazy smoking and running problems.
Old Sep 10, 2011 | 06:48 PM
henslee's Avatar
henslee
ill hopefully be flushing that filter with diesel cleaner today so we'll see if that works. And also...
it has the automatic glow plug system, is there any way to tell if they are/aren't working correctly, if the cleaner doesn't work?
Old Sep 10, 2011 | 08:00 PM
Franklin2's Avatar
Franklin2
How old is your filter? The idea is not to flush the filter. The idea is to put a new filter on it, and instead of pre-filling it with diesel to make the engine start easier after the filter change, to instead pre-fill it with the fuel system cleaner. Once you start the engine, the 100% fuel system cleaner gets sucked into the pump and the injectors, and the engine actually runs off of this cleaner for awhile and it knocks stuff loose in the system.
If you have a brand new filter, I would still pour it out in a bucket and see what's in it. If you see debris, trash that filter and get a new one, you are not going to get that one clean enough to work. If you have debris in the filter, that's a sign you are sucking stuff from the tank, and it may take a couple of filter changes to clear it out.
Old Sep 10, 2011 | 08:44 PM
henslee's Avatar
henslee
The filter is almost brand new, i took it off and didnt find any debris, filled it with Sea Foam engine cleaner, and ran it, but it didnt seem to help a whole lot. But the engine is sounding like its not firing from all 8 at an idle, and its constantly pouring out bluish smoke. So im wondering if it might be glow plug problems, but i dont know how to tell if plugs have gone bad or not.
Old Sep 10, 2011 | 09:12 PM
Sw1tchfoot's Avatar
Sw1tchfoot
The glowplugs don't matter, if it sounds like it's missing then it's an injector.
They only help with cold starts, they are not even active or needed when the engine is running.
It sounds like you have a fuel delivery problem, and a bad injector. I don't know if your truck would have a filter at the tank selector valve or not.
Old Sep 10, 2011 | 10:54 PM
henslee's Avatar
henslee
yeah its got a filter right after the tank switch valve, previous owner put it there. whats the easiest way to check the injectors?
Old Sep 11, 2011 | 07:42 AM
Franklin2's Avatar
Franklin2
I would take that filter the previous owner added off. It can quickly clog and give you fuel delivery problems.
If you think you have a bad injector or two(sounds like you could) get the engine running, and then go to each injector and crack the line nut loose so it starts leaking. The injector has a spring in it and requires over 1500 psi to open, so once you crack the line that injector will not open anymore. If the engine gets worse, than that injector is working. If the engine stays the same, then that injector is not working. It's just like pulling a sparkplug wire on and off to find a dead cylinder.
Old Sep 11, 2011 | 04:44 PM
henslee's Avatar
henslee
alright sweet, ill get on that and hopefully find something to fix, nothing better than no clue, and endless possibilities to troubleshoot...keeps me busy and gets me hard. thanks for the help guys
tshrager
17
Jun 17, 2011 11:29 AM
zax2000
15
Jun 1, 2011 07:30 AM
RA31925
May 19, 2011 10:40 AM
raptor2005
Jan 18, 2010 02:09 PM
operator73102
15
Jul 31, 2006 07:37 AM
